Stutter while cruising - Page 2
Old February 3rd, 2012, 12:13 PM   #21
ccm302's Avatar
2003 Mustang GT V3
ccm302 is on a distinguished road
I had a DPFE go bad on a Lightning I had. When it started going bad, the stuttering got so bad that I either had to be constantly accelerating or decelerating to make it run normally. It only would do it on long trips (most times). Beyond that, I honestly have no idea. I've never had any experience in dealing with the IMRC. O2 sensors (typically) don't make the car stutter (at least no in my experience). I think when an O2 sensor goes bad, the computer reverts to a default/middle of the road signal for the emissions since it can't see the actual reading. That kills your fuel mileage a little because it doesn't try to adjust the air/fuel based on the emissions. Or I could be completely wrong on all of that.
Old April 2nd, 2012, 07:53 PM   #22
ccm302's Avatar
2003 Mustang GT V3
You ever get it figured out man?
Old April 2nd, 2012, 08:12 PM   #23
Jesus Freak - 4V Fan
cobrabro is on a distinguished road
Well yes and no. Took it FPS in Marietta, GA and the owner is SCT certified and said that the tune I had from BAMA had 36 degrees of timing down in the lower rpms' which is too much for no irmc's with the tumble ports. He backed it down to 32 and plugged the egr back in. He said the computer is sensing too much timing, backing off and then back on. It definetly improved the stutter / trailer hitching effect but a little still remains. He also expanded on the tune some.
So it's feels pretty good but I am wondering if we should back off on the timing even more although I want to keep as much tourqe as I can for daily driving.
I have heard of other guys running mid 30's of timing with no irmc's but maybe that was not on 98 tumble ports.
Thanks for asking man,
Threads Similar to: Stutter while cruising
Cruising speed stutter and RPM drop. joshua022 5.0 Mustangs 5 October 26th, 2011 09:29 AM
Low RPM stutter sharkbait 99-04 5 August 25th, 2010 11:03 AM
Rough idle, stutter on take off, stutter under full throttle. zhisel 96-98 5 April 12th, 2010 10:14 PM
Stutter 94blakonblak 5.0 Mustangs 2 July 23rd, 2009 11:36 PM
Stutter At Low RPM psychostang 5.0 Mustangs 3 May 26th, 2006 08:41 PM
