4V Build Q's Blockwork
Old November 30th, 2011, 10:16 AM   #1
Travstang's Avatar
Travstang is on a distinguished road
Hey ya'll, I've been gather parts here and there little by little for my carbed 4.6 32V Cammer build for my 66 F100 shortbed. I've been curious if anyone uses oil restrictors in the block like you would on normal pushrod engines, especially in stroker engines like my 331. My 331 carries awesome oil pressure even in high temps on a normal volume oil pump. Im not sure if they would help oil on the bottom end, or if you could even use them in these engines, since ill be building a 5.0 stroker eventually
Also one trick that i think is well worth the time, painting the inside of the block with Glyptal enamel. Im not sure if anyones done something like that on the cast iron 4.6 blocks, don't know if it would be a benefit on the aluminum blocks or aluminum heads?
I've never built a modular before, just trying to see what tricks I can bring over from the pushrods! Whats your guys opinions on both these?
1969 Ford Mustang GT Grande Coupe
331 Stroker Street/Strip car, The Sweet 69
1966 Ford F100 400 Boat ancor BBF, blown C6 trans, different engine combo soon. The Sweet 66
My lug nuts require more torque than your Honda Civic makes
Old December 1st, 2011, 10:51 AM   #2
4v Know-it-all
na svt is on a distinguished road
Oil restricotrs aren't needed nor recommended in mod motors. Glyptol, I've used it in the lifter valley of old school pushrod motors but it's not needed in these engines.
The only 4v carb intake is the sullivan and it kills torque and mid range power. So, putting it or a similar intake on a small cube engine in a heavy vehichle would result in very poor driveability. A 5.4 would be a much better option than a 4.6 as it will provide some tq even with the very short runners of a carb'd intake.
Old December 14th, 2011, 01:49 AM   #3
Travstang's Avatar
The truck should weigh as much if not less than 3500 lbs when its all done, id like to use a 5.4 but sullivan doesnt make their intake for the 5.4 anymore. Ill be running a 9" with either 4.56s or 4.11s thru a 5 speed tranny i have out of a cobra
Old December 14th, 2011, 08:49 AM   #4
4v Know-it-all
5.4 Sullivan's are available on the forums; I see them for sale quite often.
There are other options that would work and provide more tq than a single plane intake like the Sullivan.
Old December 29th, 2011, 04:01 AM   #5
Travstang's Avatar
What other options would there be? Ive got a couple other options in mind, its just moving more towards injection. But then id need a computer harness, fuel rails, injectors, maf, etc... Id just like to keep it simple for now. I could go to a 5.4 but id like to use a 4.6!
But if you know of other options shoot away!
Old December 29th, 2011, 10:14 AM   #6
4v Know-it-all
Adding a computer does bugger up things.
For 4.6 the intake options are:
-the stock cobra/mach, great for torque
-Aviator intake-can be made to work great with a little work
5.4 options:
-sullivan (carb or injection)
-the new Boss 5.0 intake (will fit with a little work)
-Navi intake, great for tq
Threads Similar to: 4V Build Q's Blockwork
build 2v or swap to 4v and build? Garagebuilt01 99-04 33 December 7th, 2011 11:38 PM
310 build need help looking for 11.50 willybuck 5.0 Mustangs 30 April 10th, 2009 04:47 PM
new build 93GT 5.0 Mustangs 19 December 29th, 2008 09:21 AM
331 build pitbkr08 5.0 Mustangs 10 December 20th, 2008 03:57 PM
