New here have a few questions!
Old December 7th, 2011, 02:29 AM   #1
TCB247 is on a distinguished road
Okay, so I just bought a 99 cobra about two months ago. I wanted to get some opinions about the car. First off I love it and I used to be a big bowtie fan, however I am no longer! First things first. I did some research and I think the car has a 4.10 or 4.30 gear as running about 75/80mph on the highway I am just over 3k rpms. This could be wrong but just what I have gathered. The car has a Vortech E-trim kit on it. BBK long tube headers, full exhaust with high flow cats. Not really sure if any of the bottom end or heads have been messed with. The car only has 50k on it and Runs like a champ. I have no idea what kind of tune the car has and I havent had the time to take it to a shop. I was just wondering what some of you guys could predict as far as rwhp numbers the car might put down, and if I am correct about the gearing. Also the car has 295/35R18 I dont know if that inch is enough to really make that much a of a difference with the speedo. Any information/opinions would be greatly appreciated.
Oh, almost forgot. Would like to get some opinions on getting a new bottom end. I live in Atl GA and didnt know if I should go with a local shop to build it.
Old December 7th, 2011, 03:32 AM   #2
NOR*CAL's FINEST
3valveStallion's Avatar
2006 Mustang GT
Established in the back of a Boss 429 circa 1988
3valveStallion will become famous soon enough
depending on what gear you were in, I think you have 3.73s , 4.10s are a possibility. all in all it sounds like you scored a nice Mustang & Welcome
Originally Posted by sclass-hole View Post
One of them involves a bag of skittles, 2 grams of smack, a midget, 2 wheelchairs, an asian tranny and 4 miniature horses. The other I'll take to my grave.
Old December 7th, 2011, 03:40 AM   #3
More show than Go
azure mach!'s Avatar
2003 mustang mach 1
azure mach! is a jewel in the roughazure mach! is a jewel in the roughazure mach! is a jewel in the roughazure mach! is a jewel in the rough
what PSI are you running your vortech at?
2000 trans am ws6 - Rest In Pieces
2003 Mach 1 - Weekend Warrior
1998 taurus - DD
Originally Posted by Jazzer The Cat View Post
I have never sucked donkey balls
ok... just once though
Old December 7th, 2011, 04:39 AM   #4
3k at 75/80 is in 5th gear.
Umm I am not sure exactly how much boost. I really dont drive her too hard that much. But I know a few times I have glanced over at the gauge at 5-6k it looks to be about 8psi give or take. I would like to take it up to 12 or 14 once I get a forged bottom end.
Old December 7th, 2011, 08:44 AM   #5
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
If you want to know for certain what gears you have, place the rear axle on jackstands, place the transmission in neutral, and count the number of driveshaft revolutions it takes to make one complete turn of the tire. If the gears have been changed, you don't know if the speedometer has been corrected, so the XXXX rpm @ XX MPH isn't particularly accurate. The altered tire circumference will also throw that off.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 8th, 2011, 01:34 AM   #6
Anyone with a guess on rwhp?
Old December 8th, 2011, 05:55 AM   #7
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
id say probly low 400s.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old December 12th, 2011, 03:37 AM   #8
T.Richardson's Avatar
T.Richardson is on a distinguished road
depending on how much PSI your running, I would say high 300 to the wheels.
Old December 12th, 2011, 03:43 AM   #9
Token asian guy
swervo's Avatar
'11 Grabber Blue GT
swervo will become famous soon enoughswervo will become famous soon enough
Send a message via Yahoo to swervo
I would say mid to low 400s. I've seen many mach's with superchargers running around there with that much boost. I know my mach with twin turbo's and minimal timing put down 460 at the wheels. There is an awesome engine shop right there in Marrietta, GA called Proline Racing. Pro Line Racing
'11 Grabber Blue GT
swervo if I ever go gay I'm totally going to marry you
Old December 12th, 2011, 08:36 AM   #10
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I plugged the numbers into one of the handy axle ratio optimization sheets I created for work and came out with this:
Assuming the T3650 has a 0.68 top gear, your tires are 772 rev/mi (295/35R18), I plugged those in to find approximate gear ratios.
80mph with 4.30:1 RAR puts you at 3009 RPM. Sounds about what you were guessing? If it were 4.10:1 it would only be 2869 RPM at 80 mph.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Threads Similar to: New here have a few questions!
Dual Fuel Pump Questions and Auto Trans Swap Questions.. Mustang46 99-04 9 October 12th, 2010 12:19 PM
ok more Pi questions starin 96-98 15 July 12th, 2010 02:01 PM
Few Questions? CTown Stang 96-98 11 January 4th, 2008 11:35 AM
AOD Questions? 78mach1 5.0 Mustangs 24 December 30th, 2007 09:46 PM
Questions About T-5 fastford3388 5.0 Mustangs 5 November 27th, 2007 03:16 PM
