Cobra main cap
Old December 7th, 2011, 06:51 PM   #1
2006 mustang v6
15.4
leviathon is on a distinguished road
Cobra main cap
Ok well heres my question guys, I just got a 4.6 iron block from a 01 gt to start my cobra build. My question is what is the typical cost and how hard is it to convertr a two bolt main into a four bolt main and also would I need to mod anything else to make this a cobra block?
Old December 7th, 2011, 08:52 PM   #2
4v Know-it-all
na svt is on a distinguished road
It'll be cheaper to get a cobra block. Why not go with an aluminum block?
Old December 7th, 2011, 08:56 PM   #3
2006 mustang v6
15.4
Because I want the strength of the iron block, and I also picked up the block and crank for 75 $. I'm just wondering if the main cap is t the only thing I need to do to make it a cobra
Old December 7th, 2011, 09:04 PM   #4
4v Know-it-all
Adding new main caps will not make a GT block a Cobra block. Unless you're making over 800hp any of the aluminum blocks will work. Why add 80lbs to the front of an already front-heavy car if it's not needed.
Old December 7th, 2011, 09:10 PM   #5
2006 mustang v6
15.4
Like I said orignally, I got it for 75 bucks haha. The whole engine build idea was to have something that hovered at about 650hp but could have close to 1000hp if i really wanted it too do it.
Old December 7th, 2011, 09:13 PM   #6
4v Know-it-all
I have friends making over 1000rwhp with teksid blocks. If you want a cobra block, get a cobra block.
Old December 7th, 2011, 11:33 PM   #7
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
Teksid FTW
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old December 8th, 2011, 09:03 AM   #8
2006 mustang v6
15.4
Ok im getting the iron block is crap haha
Old December 8th, 2011, 09:08 AM   #9
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I'm assuming the "Cobra" block you're referring to is the 96-01 Cobras, not the 03/04. The 03/04 had the same Romeo iron block as the GT.
The iron block is stronger, but as mentioned the aluminum Teksid/WAP blocks will hold you to over 800 anyway, and will save you lots of weight in the process.
The iron block isn't "crap," it's just heavy.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old December 8th, 2011, 09:15 AM   #10
2006 mustang v6
15.4
Ok I apologize I was referrimg to the terminator block, only reason I was using this one ia because I got for nothing lol
Old December 8th, 2011, 09:24 AM   #11
MM's king of Neon's
404 - car not found
17.81@87
Well in that case you're pretty much there. My 03 Cobra block is a dead ringer for the Romeo block P71 I just pulled out of my GT. I believe there's a slight difference in oil pan, oil pump, and obvously rotating assembly, but the block itself should be the same Romeo iron block. It is a heavy sumbitch though, especially with those massive DOHC heads.
If you're not going for insanely big power an aluminum block would certainly help, but I also understand the value of thrift. You can get aluminum blocks not just from Cobra's but from MKVIII's and late model Explorer's as well. Though I believe the MKVIII's are Teksid and the Explorer are WAP.
Fun fact- I found out the cylinder heads we're using on some of our engines here are from Teksid.
Old December 8th, 2011, 09:33 AM   #12
2006 mustang v6
15.4
Well I just found out that if I do tap it to four bolts the jack screws would stretch alot, so either sell out to the junk yard for some money towards a aluminum block or make this work in my s197
Old December 8th, 2011, 09:35 AM   #13
4v Know-it-all
Teksid blocks only came with B heads and 99/01 C heads. The 99/01 heads are similar to the 03/04 heads have smaller exhaust ports and no short turn radius so their low lift intake flow isn't nearly as good as the 03/04s and the FR500s.
Old December 8th, 2011, 09:46 AM   #14
MM's king of Neon's
404 - car not found
17.81@87
Not sure why you would want to tap the mains...
These are some pretty damn sturdy mains. You've got the main bolts, the jack screws, and the side bolts holding it in place. You've got to be pushing some obscene power for this to be an issue.
What kind of build are you planning anyway?
Old December 8th, 2011, 11:42 AM   #15
2006 mustang v6
15.4
The idea is hover aaround 650hp but be strong enough to go 1000 of I want, I'm more a torque guy
Threads Similar to: Cobra main cap
Main girdles GreenMustang00 5.0 Mustangs 9 October 27th, 2011 08:03 PM
Rear main help please fastregalwe2 2005 - 2010 2 April 23rd, 2010 03:35 AM
main bolts? Boostang 99-04 1 July 12th, 2009 04:58 PM
main Bearings hooligan 2.3 Mustangs 0 March 31st, 2008 12:18 PM
whats the difference between a 2 main and 4 main White Thunder 5.0 Mustangs 33 September 25th, 2007 09:02 PM
