LinkBack (1) | Thread Tools |
#1
2003 MUSTANG GT
![]() ![]() ![]() ![]() iTrader: 10 reviews
2-piece headers (Flowtech, hooker, etc)
What needs to be done during install? Do I need to weld where they connect or are they snug enough to leave alone? They will also be wrapped.
![]() 4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton 4v MMR Stroker 1000 / Posi Race Ported Eaton Build How To: 2v to 4v COP Swap |
2003 Mach 1
Guessing you mean the drivers side is 2-piece so you dont have to disconnect the steering shaft, I had some Hookers on my 98gt that were the same way, the slip fit on the pipes was actually really tight, i didnt do anything to the connection and never had any leaks, plus with yours being wrapped you will probly never have a leak either. I say put them on, if it leaks you can always weld it through the wheel well later, but mine never leaked. Mine were coated as well, so i dont know that if your arent and the rust you might have a problem.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
MM's king of Neon's
404 - car not found
17.81@87
All I can say is completely remove the steering shaft before installing. There's a pinch bolt by the rack and one under the steering column. Disconnect both, yank it out of the engine compartment, install engine.
Also be forewarned, the two middle bottom bolts on the drivers side are a pain in the dick to tighten. Learn from all the time I wasted; Leave the engine mount hanging by the rearmost bolt, install headers, tighten header bolts, re-install motor mount front bolts and tighten down.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/241815-2-piece-headers-flowtech-hooker-etc.html
| Thread 2-piece headers (Flowtech, hooker, etc) | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 22nd, 2012 06:55 PM | |
Threads Similar to: 2-piece headers (Flowtech, hooker, etc)
| Flowtech headers | JMsteelers11 | 99-04 | 4 | July 22nd, 2011 07:33 AM |
| will flowtech headers fit my 04 gt? | 40thgtvert | 99-04 | 15 | April 22nd, 2010 05:23 PM |
| flowtech headers | kyle2002stang! | 99-04 | 10 | February 24th, 2010 10:24 PM |
| Flowtech Headers | F8L GT | 99-04 | 36 | January 18th, 2009 10:55 PM |
| Flowtech Headers | 00vabchgt | General Tech | 4 | March 3rd, 2007 08:17 PM |
