2003 Mach 1
13.1@108
Mach 1, 96-98 cobra cams dialing in questions
I just got a nice Christmas bonus and gunna spend the money for more power in my Mach 1, I see 96-98 cobra cams all over from $100-$200, I would be installing them myself but I don't know how to dial in cams.
So my question is this how much wheel horsepower would I gain if I just replaced the cams "dot to dot". And also let's say I were to shuffle out the money to have someone professionally dial them in, how much would it cost and would the amount of wheel horsepower I would gain from doing so be worth the price. I would also be getting a custom dyno tune after words. |
Authorized Vendor
![]() Join Date: Feb 2009
I gained exactly 20 rwhp, D2D method.
You wont gain any substantial amount more by degreeing them. BUT you will acquire a better power curve if degreeing them properly. I will see if I can find an example for ya...the low/mid range benefits greatly from degreeing.
Kelly Aiken "The Ford Guy" BMR Suspension Inc kelly@bmrsuspension.com 813.986.9302 CLICK IF YOU LIKE BMR SUSPENSION |
Authorized Vendor
#4 | |
MM's king of Neon's
404 - car not found
17.81@87
If you have any questions about degreeing let me know and I'll do my best to help. 20 rwhp just from the 96-98's? Damn, I mostly heard closer to 10rwhp. That gets my hopes up for what I'll gain from my FR500's at 111/117. I might need to pulley it down more and get a single blade but I want to crack 550 so badly.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
Authorized Vendor
Final Numbers, 346/331
[IMG] [/IMG]Before Cobra Cams, After Cobra Cams....Untuned. Just drop in and go.
2003 Mach 1
13.1@108
Sweet, thanks a bunch, what all was done to the Mach 1, I'm shooting for 340+rwhp so it would put me in the 400 crank horsepower range, I threw mine on the dyno in the summer and with JLT intake, Mrt o/r h-pipe, Borla stingers, 4.10s and a X3 tuner with a preloaded tune and it made 297 rwhp and 310 rwtq. A few months later I desided to do a little tune up by getting some NGK Tr-55 plugs(old ones were still stock), replaced the old fuel filter(looked very old) and even threw in a 90mm MAF in. I'm hoping that put me at least at 300rwhp. So with cobra cams, a php intake spacer, and an electric water pump Im hoping I'll hit 340rwhp. I just want 400 crank horsepower really bad being NA.
How hard would it be to dial them in myself or at least get them close enough to be happy. Last edited by WooMach1; December 22nd, 2011 at 12:36 PM. |
#7 | |
MM's king of Neon's
404 - car not found
17.81@87
OTC cam replacement set, Crane piston stop, a solid lifter, a generic degreeing set (wheel and dial basically) and a bigass C-clamp will do the trick. The OTC kit isn't required but it makes life much easier.
2003 Mach 1
13.1@108
I have 2 options of itstall, I can do it myself or I'm can have my friend/mechanic do it at his house, he charges me $40 an hour, he has a garage that he has his own hydraulic car lift and a shit ton of tools. He's been working as a mechanic for a GMC/Chevy dealership for 32 years.
Wyatt's #1 Slut
N/A
Do you want the expierence of doing it yourself? Do you have the patience to learn? Answer those questions first..
If you say no for both questions then have your friend do it if you can trust him. |
#10 | |
MM's king of Neon's
404 - car not found
17.81@87
![]() But I agree with B's04. You'll need to be a patient and mechanically apt.
Wyatt's #1 Slut
N/A
2003 Mach 1
13.1@108
I'd love to be able to do it myself, just so I can say I did it myself. But then I'm also a little afraid if i were to mess anything up something might happen. I do trust my friend he did my 4:10s for me and I watched him do it, took him 9 total hours for both the gears and the bearings and he went above and beyond, making sure everything was perfect a fit correctly double, triple and quadruple checking everything before moving on even used 4 cans of brake cleaner to clean out the my whole rear end of old oil and grease before putting the new in. And he only charged me $300. Like i said, I watched and helped him as much as I could and learned alot, sometimes I just feel more comfortable having an expert with me just so if anything were to go wrong he would catch it and know how to fix it right away were i would have no idea. I'm really not sure how hard or easy this but when a expert only charges you $40 an hour and let's you watch and work hands on with him, as well as doing really good work, it's kinda tempting, you know what I'm sayin?
2003 Mach 1
13.1@108
Exactly how hard is it to this swap
2003 gt
5.4 32v on the way
id have your friend do it and be there with him to help and learn.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#15 | |
Mustang Fanatic
2003 Black Mach 1
Mine has JLT, 1/2" Plenum Spacer, American racing LTs w/ or 3" X pipe, Borla stingers and was custom dyno tuned at amazon performance in SC. Mine did 310rwhp. I would really like to get another 20-30 out if it. I was thinkin throttle body, U/d pullies but ive been told ill barely get a gain from those. Cams and a getting the heads ported would probably be the best way to stay NA and get some whp. Ive heard of bolt on machs with ported heads makin 360rwhp, that would be NICE!
![]() 03 Mach 1, Full bolt-ons, Dyno Tuned, Always Clean. |
4v Know-it-all
Threads Similar to: Mach 1, 96-98 cobra cams dialing in questions
| Cams for the mach 1 | 2003MACHWON | 4V / SVT | 18 | October 24th, 2010 07:05 PM |
| changing mach1 intake cams with 96-01 cobra cams?? | blue03mach1 | 4V / SVT | 19 | November 11th, 2009 02:11 PM |
| Drunk Dialing Rules | TurboLX | The Clubhouse | 3 | September 28th, 2007 10:15 PM |
