1997 Cobra
Clutch Pedal Rattle
I just had a new zoom stage 3 clutch put in. after about a 1000 miles the pedal rattles a bit. Seems that it needs more adjustment. Anyone had this problem?
2003 gt
5.4 32v on the way
did you change the throw out bearing as well?
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
1997 Cobra
Yes, I'm thinking maybe a firewall adjuster????
Zoolander
04 Cobra #2260/3768 1/820
If your going to get a firewall adjuster go ahead and get the clutch quadrant also. These cars were made with shitty plastic clutch quadrants that wear out over time. I went with Steeda which is an all metal piece, and loved it.
Resident DJ
'01 Cobra Vert.
Did you put an OEM Throw Out Bearing in?
On Probation
My sister
Faster Then My Mom
There is usually a spring that holds the pedal at the top, if left off the pedal would ride on the throw out bearing.
1997 Cobra
No, clutch came with the replacement release bearing,Lefty . If i put just the slightest pressure on the pedal, it feels like it should. There is also a faint noise that I know is the release bearing. This noise also stops when i just touch the pedal. I'll def get the Steeda quadrant, I saw that when I was looking at adjusters. Like the jiggling picture, also Cricket.....
1997 Cobra
I'll check for that spring today, Houston
Threads Similar to: Clutch Pedal Rattle
| Clutch pedal?????? | brandon444 | 5.0 Mustangs | 5 | April 30th, 2011 04:10 PM |
| clutch pedal vibration and excessive clutch chatter | mscribellito | 99-04 | 13 | August 19th, 2010 04:59 PM |
| clutch pedal rattle | MineralGreyGT | 99-04 | 37 | October 24th, 2009 10:30 PM |
| clutch pedal | xxrals22xx | V6 Mustangs | 12 | March 4th, 2007 01:07 AM |
