03 Cobra Inner Accessory Belt (6 rib) Length
Old January 6th, 2012, 09:39 AM   #1
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Ok, so I'll probably seem like an idiot on this one.
I'm trying to get the accessory belt on, the inner 6 rib one, not the outer 8 rib supercharger one, and it just seems to be far too short. This one came with the blower kit, and has the number 960K6 on it, indicating it is 96" length, just as recommended.
Can anyone verify if this is the correct length?
Is there anything I might have done that could have changed the length? All timing cover pulleys and WPP are OEM Cobra ones, but the PS and A/C are still the GT ones. I can't imagine Ford changing pulley diameter for those.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 6th, 2012, 10:06 AM   #2
On Probation
Houston mustang guy HMG's Avatar
My sister
Faster Then My Mom
Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG
Your Ford parts man can probably tell you the length, either that or he can put one on the counter for you to compare.
Old January 6th, 2012, 10:11 AM   #3
MM's king of Neon's
404 - car not found
17.81@87
You're a funny man. When I go into the Ford parts dept here and they hear the words "03 Cobra" they look at me like I have 3 heads. So far every single part I've ordered from them takes a week or so to get, so they couldn't even compare.
Same generally goes for the larger parts stores.
I was hoping some 03 Cobra guys might have some better info.
Old January 6th, 2012, 11:03 AM   #4
On Probation
My sister
Faster Then My Mom
I'm sorry, I live in a big town with lots of Ford racing and SVT dealers, It didn't occure to me that parts guys would be like yours.
If none of these guys can help you I will go to the parts man hear and get you the info.
I just came back from the parts guy and he sent me a picture and said it was 96 inchs. I'll send you the picture if you e-mail me. fireltb at hotmail dot com
Old January 6th, 2012, 11:52 AM   #5
MM's king of Neon's
404 - car not found
17.81@87
Dammit. Well I've got a 96" belt and for some damned reason it's too short. I'll have to see if my use of GT PS and AC pulleys would affect this.
Old January 6th, 2012, 03:26 PM   #6
On Probation
My sister
Faster Then My Mom
belt tensioner or incorrect routing
Old January 6th, 2012, 04:23 PM   #7
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
The AC's are all the same. I am also pretty sure the power-sterrings are all the same.
Can you post a pic on how you are trying to route it? If you think the routing is correct, you can take and route a peice of string and then measure to get closer to the size you need.
The stock size 03-04 cobra belt is 96.
Old January 6th, 2012, 04:31 PM   #8
MM's king of Neon's
404 - car not found
17.81@87
That's what I figured.
And I was using the Ford FSM for the belt routing. I'll double check my work and try again tomorrow.
I just wanted to explore this since some of the stuff from the blower kit (especially this motherf*ckin harness!) hasn't always been correct.
Old January 7th, 2012, 07:07 PM   #9
MM's king of Neon's
404 - car not found
17.81@87
Follow up:
Checked the FSM for belt routing. I was doing it correctly.
The only thing that wasn't OEM Cobra was the PS pump since I'm using my GT one, so I began to suspect that might be larger diameter than the Cobra one. I confirmed with another member (looooots of reps to Termi_GT) that he's running a 96 Cobra belt, which I looked up to be 97.5" length, a full 1.5" longer than the OEM Cobra.
As far as pump speed this means that I will be spinning the pump slightly slower than the Cobra does, so there is no concern of over-spinning like there is with the alternator.
So there's yet another lesson learned for anyone doing the overly complex GT to Cobra swap.
Old January 7th, 2012, 10:18 PM   #10
termi_GT's Avatar
12.41@114
Follow up:
Glad my typo could help!
MM FOBRA CLUB CO-FOUNDER
Old January 9th, 2012, 05:42 AM   #11
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
Glad I saw this. So I will also need a 96 cobra belt? Is there any way it would be easier/cheaper/possible to get a smaller ps pump pulley?
Sent from my Autoguide iPhone app
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old January 9th, 2012, 05:42 AM   #12
codycat91's Avatar
2003 MUSTANG GT
iTrader: 10 reviews
Also, how are you making out on the wiring harness?
Old January 9th, 2012, 08:24 AM   #13
MM's king of Neon's
404 - car not found
17.81@87
It was a typo on Termi_GT's part, he meant 96" Cobra belt, so back to square one.
So far no one, (myself included) has been able to point out something wrong with my installation, so it may just be a case of needing a longer belt. My suspicions are in the 97"-98" range. I'll update when it gets done this week.
Also, wiring harness is a PITA. Got some of it pulled apart this weekend, but between prototype progress reviews at work and a hell of a cold progress is slow.
Old January 9th, 2012, 08:29 AM   #14
codycat91's Avatar
2003 MUSTANG GT
iTrader: 10 reviews
Do you think it would have been a little easier to mock up the wiring harness on the motor outside of the car? That's what I plan on doing. I want to have everything mocked up before I put it in, as far as modifying the wiring harness for the cop's and alternator...
Old January 9th, 2012, 08:32 AM   #15
MM's king of Neon's
404 - car not found
17.81@87
I'm doing it by overlaying it over my Cobra harness, which means I can do it in the comfort of my living room.
(Although the gf doesn't appreciate wiring harnesses all over the living room floor for some reason.)
But doing it on motor would probably make it pretty easy as well.
Old January 9th, 2012, 08:34 AM   #16
codycat91's Avatar
2003 MUSTANG GT
iTrader: 10 reviews
Oh that's right lol. I forgot you had that Cobra one too, you sneaky bastard.....
Old January 15th, 2012, 04:12 PM   #17
99Ls1fever's Avatar
2ndPlaceSetofSteakKnives
99Ls1fever is an unknown quantity at this point
subscribed for info
03' Cobra | 3.4 Whipple | SRA Swap |
99' SS | Forged 347 | YSI 16psi | 12 Bolt |
96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's |
91' GT | GT40 Intake | CAI | Headers |
www.fquick.com/99Ls1fever
Threads Similar to: 03 Cobra Inner Accessory Belt (6 rib) Length
procharger belt length? mustanginky 99-04 10 November 20th, 2011 08:56 PM
Need help with belt length cobrafox 5.0 Mustangs 6 August 18th, 2010 04:10 PM
accessory drive belt ZoomZoomMFer 4V / SVT 0 July 3rd, 2010 07:50 PM
hp gain from removing accessory belt rakkassan34 2005 - 2010 5 August 5th, 2008 01:08 PM
Serpentine belt length travis_afx 99-04 9 February 2nd, 2008 05:39 PM
