For those of your running Weld wheels..
Old January 13th, 2012, 10:49 PM   #1
Supra's Avatar
2004 Mach 1
12.57 @ 111.72
Supra is on a distinguished road
Im wanting to get 15x8 and 15x3.5 Weld Pro star drag wheels for my 04 Mach 1
Im told a 15x8 with 5.5" backspacing is what I should go for. Will this clear the rear brakes?? If not what is required??
And as for fitting a 15x3.5 on the front, what did you have to do exactly? Spacer? ( if so what type) Caliper grinding required?
Im also not sure what I need for wheel studs.
Any help/info is greatly appreciated.
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light
2004 Mustang GT - Sold
Old January 14th, 2012, 01:40 AM   #2
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
If you're looking to purchase new, I would highly suggest going with the newer Weld wheels, the RTS series. They're a new SFI approved street strip wheel we offer, that in the medium pad height design will clear OEM Cobra brakes and fit 1999-2004 solid rear axle equipped Mustangs perfectly. They're not a whole lot more per wheel than the Weld prostar wheel. They are light, come in polished or anodized black finish, and are affordable..and will fit with no spacers or grinding.
There's a reason Ford codenamed them the Terminator
Old January 14th, 2012, 11:43 AM   #3
skidad62's Avatar
2003 Centennial Edition
skidad62 will become famous soon enoughskidad62 will become famous soon enough
To fit the Prostar fronts you need to take a cut off wheel and trim the 3/8" ends off the studs (mostly just the non threaded portion) - then use 1" hubcentric spacers.
In the rear I run 3 1/2" studs - you might get away with stock studs at your track. No spacers needed in the rear.
Vortech YSI driven MMR 1000
Old January 14th, 2012, 08:35 PM   #4
mustang50lx's Avatar
mustang50lx is on a distinguished road
I have GT brakes and RT-S's. No spacers. No grinding.
Threads Similar to: For those of your running Weld wheels..
Anybody running greg weld racelites on a 99??? BYEBYE2U 99-04 12 January 11th, 2011 05:20 PM
weld wheels? 06SuperStang 2005 - 2010 2 February 26th, 2008 08:52 PM
weld wheels tom2000r 99-04 9 February 4th, 2008 09:09 AM
Weld DL wheels 93'_GT 5.0 Mustangs 26 May 3rd, 2007 09:40 PM
15 x 9 weld wheels on fox dmarstroker 5.0 Mustangs 5 December 3rd, 2006 11:39 PM
