2001 Mustang GT
![]() iTrader: 2 reviews
SVT Lightning Issues
The L is my DD and its been 10-60 degrees here the past few mothns. When I leave the car parked for a while overnight or something and go to start it the next day. Its a really hard start
Starter turns over fine, but the motor feels like its about to fall apart, same way it drove when I launched a spark plug. Whole truck shakes for a second then itll catch and rev up to about 1500 and drive fine all day when its warm. Any ideas? Heres a video of a cold start today where it failed to start on the first try.. Im about done with these Fords if it turns out to be something major
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
2003 Mach 1
any other probs? any hesitation or anything while drving? regular maintenance done? more details would help if there are any.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
2001 Mustang GT
Ive only owned the car for 12k miles from 86-98k, got the oil changed at ford last oil change was about 200 miles ago and it was doing it before that.
Havent changed the fuel filter Blew a spark plug back in July had it helicoiled and its been fine ever since and has done that one the temps dropped below 50*
2003 Mach 1
I say clean the MAF and IAC valve. Yea it just happened when the temps got cold, but maybe its coincedence and thats when it got dirty enough to throw it off.
And another thought, if you had the plug helicoiled in, maybe they over drilled the head hole, and your helicoil is shrinking with the colder temps, resulting in a compression loss until warm. Maybe not enough to rattle the plug out, but enough to bleed off most of your compression. Maybe cold start it with that plug boot off and see if you can hear the compression leaking out through the plug well.
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
When it hesitates like that it apears to be a fuel issue. A common problem is clogged fuel filter, failing pumps, or the Y that joins the 2 fuel pumps has split.
![]() bone stock from the factory! |
2001 Mustang GT
Would a fuel issue go away after its warm? Ive heard of the Y pipe issue on LightningRodder.com
Im going to take it in next week once I get the Mustang out of storage so I can have them test it on a cold start. Both cars will be for sale soon fortunately and unfortunately
Threads Similar to: SVT Lightning Issues
| 5.4 Lightning Cam help | Mustang02gt | 4V / SVT | 2 | December 2nd, 2011 04:54 PM |
| 04 lightning | 02MiNeRaLgRaYGT | 99-04 | 3 | January 11th, 2008 05:38 PM |
