Has anybody ever done a separate oiling system for a turbo
Old January 25th, 2012, 10:09 PM   #1
2004 mach 1
04 mach 1 is on a distinguished road
Question
i have an 04 mach 1 and getting ready to peace together a turbo kit. I was just wondering if anybody has ever done or heard of a separate oiling system for the turbo, cause id rather do that then tap into my oil pan. So if somebody could shed some light on that would be nice thanks.
Old January 26th, 2012, 09:34 AM   #2
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
It's possible, but complex, expensive, and the reliability is questionable.
To run a stand alone system you'd need a pump of some sort, a reservoir, lines, a cooler, and a filter at the very least
The reservoir and lines would be easy, possibly a pain to package though. Your filter could just be a run of the mill remote mount oil filter, and throw in a liquid to air cooler somewhere.
The hard part is the pump. There are outside mechanical oil pumps, usually belt or gear driven, but they'd be tough to fit, and likely very expensive. The alternative is an electric oil pump. Some guys use these for tailpipe turbos. The problem is that the reliability isn't the best, and if your pump shorts out, your turbo isn't going to live too long. At the very least you'd want to monitor pump voltage as well as oil pressure and temperature. If you see that temperature or pressure get too high, you'd need to shut it down pretty quick.
I think it would be much more unpleasant to run a remote system than to just tap the pan.
...or you can always run ball bearing turbos.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Threads Similar to: Has anybody ever done a separate oiling system for a turbo
Ball joint - Can't separate! WTF! dj10024 2005 - 2010 23 December 15th, 2010 03:08 PM
Oiling The Motor? 94StAnG5.0 General Tech 6 June 14th, 2008 01:36 PM
ohhh we just should have gone our separate ways... blazor The Clubhouse 14 August 20th, 2007 05:06 AM
Airfliter Oiling? MustangMatt96GT 99-04 5 July 23rd, 2007 02:51 AM
