Big bore destroked 4.6
Old January 27th, 2012, 12:07 PM   #1
mustangmanv6@yahoo.com is on a distinguished road
I was just thinking today and wanted to get your guys thoughts on this. I thought about a mid boost cobra (around 20 psi). What i was thinking is that There is a destroker crank for the 4.6 but i wanted to do a big bore with darton wet sleeves.
With the sleeves and the destroker crank you could get 4.5-4.8 depending if you bore the sleves. I think this would be a great idea. Expensive yes but it would help the rod:stroke ratio. I also think this would be neat to have a turbo cobra that spins to 9,000. And with the bigger bore i doubt you would loose any torque. This would be a neat project. And with a big bore teksid i bet you could see 1000 hp. The block prep would be near 4000 dollars but it would be cool
What do you guys think?
Old January 27th, 2012, 12:36 PM   #2
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
why? for $4000 i could build a 565 big block ford shortblock capable of 2500hp...
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old January 27th, 2012, 12:44 PM   #3
Well A. that much motor wouldn't fit in a cobra. But more than anything i mean do you guys think that it would be plausible?
Old January 27th, 2012, 12:46 PM   #4
lol it would fit because i already fit one in my car.
it would work, but there really is no point. you are just burning more money to get the same end result.
Moser built 9" Rear
Old January 27th, 2012, 12:52 PM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I was fairly certain there were 1000 hp stock-displacement Teskids out there.
I think it's certainly plausible, but you're not getting a whole lot of gain for your money. I mean, you could sink $4k into the block just to change your power curve, or you could put that money towards boost and be making significantly more power overall.
It really depends on your budget and your goals. If you've got an unlimited budget and a desire for something unique, it's certainly doable.
Remember that the beaten path is generally that way for a reason: it's typically the easiest and most efficient way from point A to point B.
O o
/¯/______________________
\_\
Old January 27th, 2012, 01:07 PM   #6
Ya thanks guys i was just toying with the idea and no one seems to have done it so i thought maybe it would be interesting. Wouldn't it help piston speeds too?
Old January 27th, 2012, 01:22 PM   #7
destroking a motor usually wears the piston rings faster.
Moser built 9" Rear
Old January 27th, 2012, 03:36 PM   #8
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
y?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Old January 28th, 2012, 02:04 AM   #9
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
You know you can get a big bore aluminum block straight from ford and not worry about the sleeves. There is also no point in revving it that high, and you will have plenty of work to do to make your entire car get along with 9000rpms, and some of it probably wont be cheap. I think if you are committed in your efforts to go along with this, try it with a 5.4L block, a big bore 5.4 with a shorter stroke might let you get your better ratios.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old February 15th, 2012, 11:05 AM   #10
Thanks guys i think i decided to just go with stock stroke. Thanks!
Threads Similar to: Big bore destroked 4.6
bore seans mustang 5.0 Mustangs 5 November 5th, 2009 09:55 AM
4.6 big bore? product1620 96-98 7 August 31st, 2008 12:39 AM
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 05:28 PM
bore gooberhead320 V6 Mustangs 5 May 11th, 2008 05:02 PM
bore Iownastang 5.0 Mustangs 11 February 5th, 2008 10:18 PM
