Some tire help please
Old January 28th, 2012, 01:50 PM   #1
PsnSnake_19's Avatar
2001 cobra
PsnSnake_19 will become famous soon enoughPsnSnake_19 will become famous soon enough
Hey guys my rear tires are going out and i wanted to buy some mickey thompson street radials 305/35/18. So my question is will my car look lower with bigger tires?? and also i wanted to know what size 18's should i run in the front?? 245's??? 225's? any upsides or downsides?? then i plan on buying new wheels but thats a different story lol
SVT all day! Next mods: Mickey thompson street radials, new wheels, gears and tuner, then turboed by 2013
Old January 28th, 2012, 07:32 PM   #2
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
I like this tire size calculator because it lets you easily compare tire sizes.
Tire size calculator
According to this, the 305/35/18 is .7 inch taller than a stock 245/45/17 so from the side you're not going to notice a huge difference. You will need 10 inch wide rims to run the 305s, not sure what you have currently. This will alter your overall gearing slightly as well.
Also according to that calculator, a 245/40/18 is the same height as our stock 245/45/17. A 255/40/18 would probably be a better pairing with the 305/35 in the back because it's .3 inch taller than stock and gets you a little closer to matching that 305.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old January 28th, 2012, 07:35 PM   #3
2001 cobra
so i should get 255 for the front and 305 in the back?? what about ppl running skinnys why cant i run 225's in the front for less weight
Old January 28th, 2012, 11:26 PM   #4
gdl
Sorry, didn't realize that's what you were after. The issue is that if you get too big a discrepancy in tire height front-to-back, the ABS and traction control will get out of whack. If you go skinnies, you still want to try to match the tire height as close as possible. Either that or permanently disable the ABS and TC. A 225/45/18 on like a six or seven inch wide rim would be appropriate and would save a little weight.
Now having said all that, I've never done the big/little combo myself so I'm no expert at it. Hopefully someone who has will chime in.
Old January 29th, 2012, 09:59 AM   #5
2001 cobra
Thanks man yea i plan to buy 18's all around i just dont see no point in having bigger then 245 in the front since i never really autocross i just go to the drag strip and don't car much for handling even though my car handles good
Old January 29th, 2012, 10:47 AM   #6
Because Racecar
Calogero6685's Avatar
2012 Mustang GT Premium
Calogero6685 will become famous soon enough
On a New Edge, I'd keep 17s so I can fit a taller tire. 17s and lowered look great.
2012 | Ford | Mustang | GT | Premium | 401A | Brembo | 3.73
BMR Suspension | Mickey Thompson | Billet Specialties
I'm tired of all our free bananas being raped at the hands of horny female Islamic fruitists.
BONER CREW EMPLOYEE - URANUS DISTRICT MANAGER
Old January 29th, 2012, 11:11 AM   #7
2001 cobra
yea well upside to 17's are ALSO mickey et streets are only $235 in that size instead if it being $295 wit 18's lol
Threads Similar to: Some tire help please
Review: Mothers FX Wheel & Tire Cleaner / Reflections Advanced Tire Care M.P. Cobra Fan General Car Care & Detailing 11 April 27th, 2011 07:22 AM
Tire pressure for 555r on street? (Tire life) 23psi max? 01MGGT 99-04 13 December 1st, 2010 01:54 AM
Tire Rack/Discount Tire zinc02GT The Clubhouse 0 March 22nd, 2010 02:10 PM
Change from 26.6 in Tire to 28.8 in Tire adam0421 2005 - 2010 5 April 3rd, 2009 05:04 PM
NEED HELP!!! Tire Tire Pressure Sensor Fault!! On Mr.Stang08 2005 - 2010 7 March 7th, 2009 12:14 PM
