Threw 2 Codes P0430 & P0420 Today
LinkBack (1) Thread Tools
Old January 29th, 2012, 10:52 PM   1 links from elsewhere to this Post. Click to view. #1
dannyboy281's Avatar
2003 Azure Blue Mach 1
5,000 miles on the ODO
dannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to all
I just got my Mach 1 today and I drove it today a bit, while I was on the highway the check engine light came on. I dont have my SCT X3 anymore because I sold it to the guy who bought my GT so I went to autozone to check what code it was throwing. It was the following 2:
P0430 & P0420, I am wondering do you guys think its because it has a MAC Offroad X- Pipe or should I be looking elsewhere to find out what it can be? What do you guy suggest I do or look for?
When I had the SCT X3 for my GT I turned of the rear O2's on my SLP catted X-Pipe but since I don't have the tuner anymore what do you guys suggest I do and do you even think its due to the off road X?
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
Old January 29th, 2012, 11:28 PM   #2
Supra's Avatar
2004 Mach 1
12.57 @ 111.72
Supra is on a distinguished road
Just thought I'd tell ya that I am extremely jealous of the condition of your car
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light
2004 Mustang GT - Sold
Old January 29th, 2012, 11:31 PM   #3
Token asian guy
swervo's Avatar
'11 Grabber Blue GT
swervo will become famous soon enoughswervo will become famous soon enough
Send a message via Yahoo to swervo
Since it's failing both banks, it's probably because of your off-road pipes. Buy a tuner and turn them off.
'11 Grabber Blue GT
swervo if I ever go gay I'm totally going to marry you
Old January 30th, 2012, 02:25 AM   #4
Just wait until I correct the paint Your going to need some shades LOL
Thanks Dewayne I will most likely have to do that again, but this time I will get a used unlocked one. (should have never sold mine) Do you have any idea if it could be something else and if so how would I know where to pin point it?
Old January 30th, 2012, 08:38 AM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Codes 0420 and 0430 are "Catalyst efficiency below threshold, data valid but low" codes. This basically means your rear HOS's are working, but they can tell your catalytic converters aren't working. Since you have no cats, that's pretty much the only plausible explanation.
Shut them off in the tune or get some MIL elminators and you're good to go.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 30th, 2012, 09:05 AM   #6
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
^^ this, or if you want to turn off the code for real cheap until you can get a tuner, go get some spark plug non-foulers and put the O2 sensors in them. Then reset the battery.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old January 30th, 2012, 09:26 AM   #7
The owner said he has MIL's on there but he said they never worked do you think this is still an issue with the off-road X or something else?
Glittle what are those non-foulers and how do I put them on?
Old January 30th, 2012, 09:30 AM   #8
MM's king of Neon's
404 - car not found
17.81@87
They could be crappy MIL's or he lied to you.
These codes monitor catalyst efficiency only. They're just an emissions compliance code. All they do is compare upstream HOS readings to downstream and see if the cats are doing their job. You have no codes for the HOS's themselves, so obviously it's the lack of cats.
You can get non-foulers in any auto parts store. They just thread between the HOS and the bung and get the sensor probe out of the exhaust stream.
Old January 30th, 2012, 11:05 AM   #9
Thank you is there anyway you could post a pic of how they look installed? It would be much appreciated because I am still a little confused on how to put them in man
Sent from my Autoguide iPhone app
Old January 30th, 2012, 11:09 AM   #10
MM's king of Neon's
404 - car not found
17.81@87
I don't have any pictures on hand, but it's pretty hard to mess up.
The MIL eliminators just plug in, one end to the oxygen sensor (HOS) and one end to the harness. Just clip em in and you're done. It's just an R-C circuit in line with the sensors.
If there's no jumper between the sensor and harness, and the sensor wiring doesn't look modified, the PO might have lied to you, which would explain the CEL.
Old January 30th, 2012, 03:21 PM   #11
Supra's Avatar
2004 Mach 1
12.57 @ 111.72
I would forget the MIL's and just get a tuner to turn the o2's off and gain a little more power. Made a huge difference on my mach!
My gt however, the canned tune didn't seem to make much difference.
Old February 1st, 2012, 10:48 PM   #12
Did my own custom MIL's with some capacitors and resistors and it cleared the code at least it hasnt come back on yet it only cost me $12 for the parts at Radio Shack. Zinc showed me a site on where to check it out and I got it done after work today.
Old February 2nd, 2012, 12:26 AM   #13
Went for a drive and the CEL came back on I wonder if the soldering disconnected. I wanted to know if I were to get new MIL's would I have to fix the soldering on the O2's for it to work or can I just plug the new MIL's in and even if a wire is not soldered together will it work?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/247971-threw-2-codes-p0430-p0420-today.html
Thread Pesky P0430 or P0420? Only when cold? Read here | F150online Forums - Message Boards for 1997-2008 F150, Lightning, Supercrew, King Ranch, Blackwood, Mark LT Light Duty Pickup Trucks | BoardReader This thread Refback April 11th, 2012 02:36 PM
Threads Similar to: Threw 2 Codes P0430 & P0420 Today
dtc codes p0420 and p0430 jason2103 2005 - 2010 6 August 14th, 2011 04:59 PM
Loss of power at all RPMs, P0430 P0420 Bryce9000 96-98 20 March 11th, 2011 11:10 AM
P0420, P0430 codes VaderGT 2005 - 2010 4 September 8th, 2010 11:18 AM
Ugh my car threw some codes today.... Rich J V6 Mustangs 11 June 9th, 2010 04:13 PM
Threw some codes silver99gt 99-04 8 October 11th, 2008 04:43 PM
