Help please
Old January 30th, 2012, 08:46 PM   #1
5.4cobra is on a distinguished road
Help please
Hi there i have a 98 cobra when i got home turned the key off and it will not start no fuel pump or fire i checked the pump and it is good i changed the ccrm and nothing the fuse was blown for the ccrm i changed it and it blow agin i changed it one more time and nothin ti didnt blow but still no fuel or fire thanks for any help u can give me the car is heavily modded
Old January 31st, 2012, 11:15 AM   #2
4vGT's Avatar
1997 4v Mustang GT
13.66
4vGT is on a distinguished road
Send a message via AIM to 4vGT Send a message via Yahoo to 4vGT
Can you list what you have done to the car? I see 5.4 Cobra so Im assuming 4v 5.4. What heads? What intake? Fuel? Are you running anything stand alone? Have you checked for a crushed power to your fuel driver? Any recent damage?
Please list more information about your car and the parts/ modifications done.
Originally Posted by VaporS197 View Post
You're a good guy, 4vGT!
Old January 31st, 2012, 11:58 AM   #3
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Kinda sounds like a short and something has gone bad in the wiring somewhere.
MM FOBRA CLUB CO-FOUNDER
Old January 31st, 2012, 12:15 PM   #4
4vGT's Avatar
1997 4v Mustang GT
13.66
Happened to me, Im from CO and got stranded in CT...
Problem? FUEL PUMP
Happened just like this- then the PATS went to hell.
Old January 31st, 2012, 12:21 PM   #5
4vGT's Avatar
1997 4v Mustang GT
13.66
HERE IS HIS INTRODUCTION, has tons of pics- Looks great!
Old February 1st, 2012, 01:37 AM   #6
navi motor with 98 cobra cams, bbk longtubes ,and h pype, with side exit exaust, richardracing adaptor plates eaton m112 stage 3 zoom clutch and a t65 tranny i got 11/2 k fram spacer plates that sits it down far enof the factory hood fits with clearince 30 plb injectors lightning mas and a sct tuner and it ran great till i turned it off thats when my troubles begain. and its got solid motor mounts
Old February 1st, 2012, 09:08 AM   #7
4vGT's Avatar
1997 4v Mustang GT
13.66
So is it still run by the factory fuel driver and ECM? Hmmmm..... What pump(s?) are you running for fuel?
Sounds like a hell of a setup!
Any PATS problems? You are getting fuel pressure to the rails? Do you have a FP Gauge?
Old February 1st, 2012, 09:30 AM   #8
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
I'd start by tracing the circuit the multiple blown fuses were on. There's obviously a short there.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 1st, 2012, 10:08 AM   #9
4vGT's Avatar
1997 4v Mustang GT
13.66
If he is running a higher draw fuel pump or the like though, he could trace the wires all day long *PITA* and wouldn't find the problem. Im thinking something is drawing way too much on the stock setup.
Old February 1st, 2012, 11:26 AM   #10
Tang Stang's Avatar
He may be, but from what I gathered from the info he gave us is that the car ran fine for quite some time before suddenly blowing multiple fuses on the same circuit.
Old February 1st, 2012, 11:29 AM   #11
4vGT's Avatar
1997 4v Mustang GT
13.66
Very true. However I really think its the fuel pump driver in the fender or the pump or pump wiring. The same thing happened to my car. Exact same. Drove to work fine, shut it off, and went to restart and nothing-
Replaced the blown fuse, and upon further investigation the harness that the pump was on actually shorted from the controller (loose connection caused resistance)
Old February 1st, 2012, 07:12 PM   #12
Sorry fuel pump out of a 03 focus
Old February 1st, 2012, 07:13 PM   #13
Fp gauge reads nothing till i by passed it at the tank
Old February 1st, 2012, 07:14 PM   #14
4vGT's Avatar
1997 4v Mustang GT
13.66
Ah! Have an OM meter? Start at the pigtail that plugs onto the tank, what does it say?
Money says your fuel driver is out
Old February 1st, 2012, 07:47 PM   #15
What is a fuel driver
Old February 1st, 2012, 07:53 PM   #16
4vGT's Avatar
1997 4v Mustang GT
13.66
CCRM
Old February 1st, 2012, 08:13 PM   #17
I bought a new one didnt change any thang
Old February 1st, 2012, 08:13 PM   #18
Those are pricey
Old February 1st, 2012, 08:19 PM   #19
4vGT's Avatar
1997 4v Mustang GT
13.66
Yes they are. Your problem lies between your fuel pump and your CCRM- Anything aftermarket?
Old February 1st, 2012, 08:21 PM   #20
No all fuel is factory excluding pump and injectors and regulator
