LinkBack (1) | Thread Tools |
#1
RADIATOR FAN STAYS ON ALL THE TIME
hi. i just got my car back from the shop. the motor was rebuilt with new cams, port and polish, headers. i noticed my radiator fan connector was unplugged when i got home. i plugged it in, and the fan came on. the car was off. what could the problem be?
2003 Mach 1
fan relay is on in the tune. if you hvae a handheld you can turn it off.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
car is on a stock tune right now though. even when i had the tuner, it only came on at specified temperatures. any other ideas?
2003 Mach 1
did it go off after a bit, or did you disconnect it again?
Does the fan in your 97 stay on after you shutdown the car to help cool the car? Or always went off as soon as you kill the car? If it is coming on with the car off, and not supposed to be, then the relay is getting power somehow, obviously, trace it back and see where the power is coming from. Fan relays are usually 5v IIRC, so i doubt its straight off the battery.
it stays on all the time if it is connected. even with the car off. it never did this. the only relay in the circuit is the CCRM. the fan is ran off a 60amp fuse in the fuse box under the hood.
2003 Mach 1
look on your coolant crossover, you should have 2 temp sensors, on sends its signal to the PCM / CCRM to turn the fan on, and the other is just for the dash guage. If the on for the PCM is bad, it sends a hot signal and will kick the fan on no matter what. Try switching the plugs between the two and see if it goes off, if it does, change the bad sensor. If not probly swap the CCRM with a known good one and see what it does, or just go ahead and replace it.
it was the low side relay in the ccrm, i cut the power to the fan after the ccrm. i then grounded up the signal wire from the pcm to the ccrm for the high speed relay through a switch. i can now turn on the high speed fan at my discretion. thank you for the help!!!!
2003 Mach 1
nice, glad you got it figured out. Sorry wasnt more helpfull.
its all good man, it actually worked out in my favor. i like the set up. thank you!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/248290-radiator-fan-stays-all-time.html
| Thread Radiator fan stays on | PT Cruiser Forum | BoardReader | This thread | Refback | March 9th, 2012 08:25 AM | |
Threads Similar to: RADIATOR FAN STAYS ON ALL THE TIME
| Amp light stays on when ignition is off!! | jw95mustang | 5.0 Mustangs | 4 | March 1st, 2011 06:45 PM |
| my dome light stays on? | davidstivers09 | V6 Mustangs | 8 | April 22nd, 2010 08:07 PM |
| gas gauge stays on empty | isenegger | Audio/Video | 1 | April 23rd, 2007 01:30 AM |
| car stays running | 95StangSVT | 5.0 Mustangs | 5 | July 1st, 2006 05:35 PM |
