Single Blade TB Worth It?
Old February 1st, 2012, 09:48 AM   #1
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Just saw a single blade Accufab TB and polished plenum for sale. I was wondering if the gains from it are worth it. Currently I've got a pullied/ported Eaton M112 on it. I know they say gains are minimal with a stock Eaton, but how about a pullied/ported one? Not to mention my cams and LT's should help move things a bit more too.
Any thoughts on whether I should pounce on this or not?
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 2nd, 2012, 05:23 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i would keep the stock setup, unless that eaton is the only sc going on the car. if your trying to ring that shammy dry then i would say it will have some minimal gains.
bone stock from the factory!
Old February 2nd, 2012, 08:29 AM   #3
MM's king of Neon's
404 - car not found
17.81@87
Well the guy is just offering it so damn cheap it's hard to pass up.
Not to mention for the next stage I'm thinking of going compound boost instead of twin screw. I think it would certainly benefit that application.
I think I might throw the guy and offer and see if he bites.
Old February 2nd, 2012, 11:51 AM   #4
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
On minor bolt-on car they really only help with smoother idle and better throttle response. BUt if you can get it cheap enough, do it. They do help out a good bit with say a whipple or a KB.
MM FOBRA CLUB CO-FOUNDER
Old February 2nd, 2012, 12:06 PM   #5
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
I watched a video from Stiegemeier that showed that a twin blade actually flows better than a single blade. They bench tested it and proved it with flow numbers. I suppose I could try to find the video later after classes
Sent from my Autoguide iPhone app
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old February 2nd, 2012, 12:31 PM   #6
MM's king of Neon's
404 - car not found
17.81@87
I'm not going to believe it.
Direct from Accufab's website:
Originally Posted by Accufab
Replace your Mustang Cobra's restrictive restrictive stock throttle body with this top of the line unit from Accufab and get your DOHC the air it's been lacking. Accufab's throttle body flows 1696 cfm compared to stock 1089 cfm.
They also put up dyno results versus stock.
Unfortunately I went to go put in an offer to see that the TB sold earlier this morning. Oh well.
Old February 2nd, 2012, 12:49 PM   #7
codycat91's Avatar
2003 MUSTANG GT
iTrader: 10 reviews
I meant a ported twin blade, not stock
Old February 2nd, 2012, 01:10 PM   #8
MM's king of Neon's
404 - car not found
17.81@87
You would have to hog the hell out of that TB. The difference in cross sectional area alone is massive. Plus we're talking an extra 600cfm of flow rate, thats about 54% over stock! You'd be hard pressed to achieve that.
Also I believe my TB/plenum is lightly ported/polished, though I can't quantify to what extent.
Threads Similar to: Single Blade TB Worth It?
Dual Single DIN to Single Double DIN Console Conversion? lil666 99-04 5 October 13th, 2010 06:08 PM
Single blade oval tb, or dual 65mm? jivepepper 99-04 0 February 24th, 2009 04:07 PM
should i get a single blade t/b over a ported stocker 03snakeminated 4V / SVT 4 October 30th, 2008 08:19 AM
Single exhaust...worth it? arhodes591 2005 - 2010 V6 2 August 30th, 2008 08:32 PM
Single Blade TB blackhavok 2005 - 2010 4 January 17th, 2008 08:36 AM
