2003 Mach 1, pulling trigger on build. Final Suggestions
Old February 7th, 2012, 11:59 AM   #1
2003 Mach 1
Black03Mach is on a distinguished road
The time has come to finally start to order the parts for the mach. Were going for 700 horsepower through a 76mm turbo with the option to go down to 500 through a tko600. Here is my parts list:
FRPP Aluminator 8.5 to 1
TKO600 from ProMotion or a built automatic
On3performance w/upgraded turbo, suspension parts, injectors,blahblah
Lethal Performance Budget Style return fuel system
Lethal Performance Cobra Fuel Tank
31 Spline Differential and Axles
UPR Bumpsteer kit
Evenflow Cooling Mod
Spec Stage 3+ Clutch
Full length Subframe Connectors
Panhard Bar
A tire to put the power to the ground.
Gonna be a good time, but is there anything i should change, add or modify. I am having Kevin from wicked motorsports build the car and i will be sure to make a thread and include pictures on the whole journey.
Old February 7th, 2012, 04:07 PM   #2
WooMach1's Avatar
2003 Mach 1
13.1@108
WooMach1 is on a distinguished road
Just curious, how much is this all going to cost you. Just looking at how much something like this setup would cost if I were to do this to my Mach
Old February 7th, 2012, 04:17 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Curious why of all the suspension mods you could pick, you've got a bumpsteer kit and a panhard bar.
Does it already have aftermarket control arms out back? Considering this looks to be a straight-line car, I'd be doing LCAs and UCAs.
I also wouldn't be looking at bumpsteer kit unless you're lowering the car, and I don't see any mention of springs or shocks.
O o
/¯/______________________
\_\
Old February 7th, 2012, 06:01 PM   #4
2003 Mach 1
On3 requires a bumpsteer kit, coilover, tubualr k and a arms. Im debating on getting the maximum motorsports rear grip package.
Rear Grip Package, 1999-04, XD, Standard [MMRG-11] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
still debating if i want to just do coilovers in the rear too as opposed to this idea.
And im hoping to spend 21k said and done, but who knows. the parts alone add up to over 16k.
Old February 8th, 2012, 02:39 PM   #5
TRMach1's Avatar
2003 Mustang Mach 1
TRMach1 is on a distinguished road
I agree with the Rev., upper and lower control arms, I went with Steeda. I'd also go with some type of adjustable shocks and struts, like Tokico D-specs. Is the Aluminator going to be just a short block? Because if it's the long block, you don't need the cooling mod, as the heads were revised to deal with that issue.
2003 Torch Red Ford Mustang Mach 1 5-speed
657 RWHP 635 RWTQ
My Mods
My Car
MODS: Yeah, it's got mods.
August 2012 AmericanMuscle.Com Calendar Centerfold!
Old February 8th, 2012, 02:54 PM   #6
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
I suggest you do your research on the On3 kit, the fitment is terrible, the welds are of poor quality, and the customer service is something to be desired. The kit was based off of a 99 Cobra, and the differences between the two result in a lot of fabrication. Not to mention the parts that are furnished in the kit by On3 are chincy...
I suggest you consider, STS, Hellion, or HP... All whom are very reputable comapnies that include everything you need in their kits. On3 doe not!
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old February 8th, 2012, 02:57 PM   #7
I.D.G.A.F.
Look on SVTP, as there is a write up about someone who went down this road and was very unhappy.
Also ModularSpeed did a write about his On3 intll on his 98 Cobra. I know he had some issues with fitment, and quality of parts.
Old February 8th, 2012, 05:02 PM   #8
2003 Mach 1
Awesome, i did not know that. I will most likely want to go with a long block to have the car ready by june for carlisle. American muscle actually sells the aluminator which entitles me to free shipping, and im only located three hours from their warehouse so fast delivery.
The thing with the turbo is I only really need the hot side, kevin would prefer to make a cold side for me because he has a way he likes. I looked and couldnt find JUST hot side products anywhere.
Old February 8th, 2012, 08:02 PM   #9
2003 Mach 1
Another issue i am having is picking a compression ratio, i read the the 8.5 to 1 is too low even for twinscrew applications. Should i go for the 10:1 compression, i really dont want the car to be a dog accelerating from a light with normal driving
Old February 8th, 2012, 11:39 PM   #10
TRMach1's Avatar
2003 Mustang Mach 1
I don't know how it would be with a turbo, but I have the Aluminator 8.5:1cr long block, and it ain't a dog in the acceleration department! And that's with 3.73 gears, and the stock TR3650 5-speed trans.
657 RWHP 635 RWTQ
My Mods
My Car
Old February 9th, 2012, 01:20 AM   #11
2003 Mach 1
Are you still on your stock 3650? I dont plan on launching the car hard at the track, not a big issue for me. I have to worry about turbo lag, not much and issue with a twin screw.
Old February 9th, 2012, 09:16 AM   #12
TRMach1's Avatar
2003 Mustang Mach 1
Yes, and it still gets the job done! It's been over three years since the build was done, and the transmission hasn't failed me yet. I have a Viper-spec T56 collecting dust in a storage locker for the day when the 5-speed finally gives it up.
657 RWHP 635 RWTQ
My Mods
My Car
Old February 9th, 2012, 09:39 AM   #13
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I saw a writeup on Corral a guy did with his SN95 Cobra and he was overall pleased with it.
Are you running pump gas? I wouldn't go over 9.5:1 on pump gas if you're boosting it. Going as high as 10:1 might require you to run lower boost or E85 if you're really going to push it. 9-9.5:1 would be a good window to go with.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 9th, 2012, 10:46 AM   #14
I.D.G.A.F.
I have heard more horror stories about On 3 Kits than good... Just saying...
Old February 9th, 2012, 11:32 AM   #15
2003 Mach 1
I understand the on3 kits, but the guy stands behind his crap and if there is an issue it gets taken care of. American muscle only has the low compression and the high compression level so i guess the low one it is.
TRMach, do you beat on the car often? Im really debating the tko, but if i can get away with the stock trans for awhile then i will. Are those your nitrous numbers? I do not plan on running slicks at the track just a street radial. More than likely going to drive the car around at 550 to the wheels but i dont want the thing to pop on me.
Old February 9th, 2012, 12:01 PM   #16
I.D.G.A.F.
Really? because I have heard of nothing but horrid stories of the company's customer service. I helped a family friend do and install on his SN95 2v. The welds were of terrible quality, and I actually had to cut some of the welds and re-weld them. I have seen better quality out of some the students in a college welding course that I took.
My T3650 gave out on me while the car was pushing around 440rwhp on the bottle. Granted I was at the track often, and did a whole lot of powershifting. I don't see how it wouldn't hold up if you're easy on it...
Old February 9th, 2012, 12:06 PM   #17
TRMach1's Avatar
2003 Mustang Mach 1
...TRMach, do you beat on the car often? Im really debating the tko, but if i can get away with the stock trans for awhile then i will. Are those your nitrous numbers? I do not plan on running slicks at the track just a street radial. More than likely going to drive the car around at 550 to the wheels but i dont want the thing to pop on me.
No, I don't beat on the car at all, and it's not a daily driver either. That's not to say that I drive it like an old lady either! I went into the build wanting a badass STREET CAR, and the street is alot more forgiving than a drag strip, or race track is. I made that one pass at the drag strip, and because I didn't have a roll cage, I was politely asked to leave and not come back until I had installed one. In all reality, that probably will never happen. I'm one of those lucky people who never had any issues with the TR3650 transmission, like grinding into second gear, third gear lockout, yada, yada. When I did the build, I ran out of funds before the transmission replacement could be done, so I rolled the dice, and haven't had a problem with it yet. I eventually got the money to buy the T56, but like I said it won't go in until this one breaks. Oh, and yes, those numbers are with the 100 shot of nitrous.
657 RWHP 635 RWTQ
My Mods
My Car
Old February 9th, 2012, 12:10 PM   #18
2003 Mach 1
Yeah, i dont mean to contradict you but the stories i read the people got either the wrong parts or some were missing and he sends em out right away. Im willing to try it because its over 2000 dollars less than the hellion with the option of kmember, coilovers, injectors, MAF. Im not installing crap (my car came with full exhaust but me and a couple friends did my springs and it was a disaster. eventually got it done 8 hours later) because 1) I dont know what the fuck im doing 2) I dont have time or tools to complete it 3)Time is certainly a factor, i want the car to be ready by carlisle in june.
That being said Ill leave it in the hands of my builder to make it work. Hopefully everything works out, i hope i dont get stranded one day because my transmission takes a shit on me, so ill most likely get the trans while the engine is out anyway.
Old February 9th, 2012, 12:28 PM   #19
I.D.G.A.F.
The Hellion kits are complete, with the On 3 kit you still have to buy a lot of stuff, so you don't end saving as much as everyone thinks. but what do I know, I only helped a kid install an On 3 kit that that was effed up...
Goodluck with your build..
Old February 9th, 2012, 02:09 PM   #20
TRMach1's Avatar
2003 Mustang Mach 1
...Time is certainly a factor, i want the car to be ready by carlisle in june...
Good luck with it! I plan on being at Carlisle also. Look me up when you get there, I'll be with the crew from The Mach1Registry.com.
657 RWHP 635 RWTQ
My Mods
My Car
Threads Similar to: 2003 Mach 1, pulling trigger on build. Final Suggestions
FS: Pulling the trigger... v6/v8 performance and New Edge Cosmetics xtreme 2 1999 - 2004 Mustang Parts 56 May 16th, 2012 11:22 PM
Thinking about pulling the trigger on this wing.. Shelbydog! The Clubhouse 15 December 27th, 2011 12:03 PM
My final build... for now davidcseifert V6 Mustangs 83 November 29th, 2011 12:39 PM
Pulling the trigger mustang fanatic 2005 - 2010 11 March 19th, 2008 08:14 PM
Pulling The Trigger dblindberg 2005 - 2010 1 February 8th, 2007 07:31 AM
