Jesus Freak - 4V Fan
Yes, Another Head Tick Video
Hey Guys,
I am hearing a tick or more like a knock in my motor. Video below with a little factory ear candy at the end - just for watching! Sounds like it is coming from the rear of the drivers side head. It increases with rpm up to probably 1,500 - 2,000 RPM where I can't hear it anymore due it disappearing or being too fast and blending in with other engine noises. You will hear it still ticking faster than I would think it should when the motor slows down which seems a little odd to me. Also, it sometimes is silent and then sometimes loud like the video no matter if hot or cold. I must admit that after a recent IMRC delete procedure, it did overheat on me a couple of times until I got it burped and re-filled with coolant. Could this be the valve guide issue on Termi's due the heat?
2003 Mach 1
im gonna go with something got messed up on your IMRC delete, an the overheating probly didnt help.
The ticking from the cobras is c-head specific. not 4v in general. You have b-heads. Sounds like valvetrain noise for sure, but i vote for valve guide after the overheating.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
12.41@114
I would suggest pulling the cam cover off on that side and checking everything. That is not a good/normal noise from a B head 4.6.
MM FOBRA CLUB CO-FOUNDER
Look Ma! My First Post!
i had the same problem in my 01 cobra, i pulled the motor and it was a rod bearing, i got luck and it didn't hurt the crank or anything else.
That's good but I don't think this is a rod bearing. (at least I hope it's not I think) It definitely sounds to be more on the top of the motor and louder on the driver side than the passenger.
12.41@114
Sometimes a bottom end sound will echo up to the top-end of the motor.
Threads Similar to: Yes, Another Head Tick Video
| Mach 1 and the head tick | mustang50lx | 4V / SVT | 9 | August 8th, 2011 09:48 PM |
| Valves....Tickity tick tick tickers tick....how much is too much?? | Bottle Fed GT | 2005 - 2010 | 17 | November 9th, 2010 07:12 AM |
| Head Tick? | rst1523 | 4V / SVT | 13 | July 28th, 2010 09:49 PM |
| you think it might be the head tick? | 97Dustang | 4V / SVT | 7 | April 14th, 2010 12:17 AM |
| Massive Head Tick | mustangmanic | 99-04 | 37 | November 6th, 2008 09:30 PM |
