1997 Pacific Green Cobra
13.4@103.95/ 2.12 60ft
4v build Valve unshrouding.
I keep hearing about this but how is it done/ what do i need to have done to my heads and or block to do it.
These are B heads . I plan to cam and supercharge them .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
bore and leave stock size valves in it. the 4v isnt in need of large lift, especially under boost.
![]() project warhorse under construction wagon burner built! track times coming soon!(04 lightning) being built by MP2 Performance follow shop builds on facebook at: MP2 Performance |
Would 30 over bore help on the shrouding ?
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
A 0.030" overbore is better than nothing, but it isn't going to make much difference. Are these the '93-'95 heads or are they the '96-'98 heads?
All B heads are not created equal - Ford Mustang Forums : Corral.net Mustang Forum
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
4v Know-it-all
4vs don't suffer from shrouding like 2V engines. The chambers can't be opened up because they are already the size of the bore and overboring does little to increase flow. Going to a 3.7" bore increases flow a little but the biggest gains are in opeining up the valve seats.
Restrictive valve seats - SVTPerformance Going with .5mm oversize valves and opening the seats properly to work with them offers good gains but, this isn't needed whn adding a supercharger. 1mm oversize valves require new seats. |
These are from a 98 mark VIII
also i was thinking of getting the cams ground by HP . Is that a good idea. i just want them to be more aggressive and pick up gains out of them .
Interesting information there
