Is this DYNO Sheet Correct? 2001 Cobra w/ minor bolt ons - Forums at Modded Mustangs
post #1 of 27 Old October 16th, 2012, 12:37 PM Thread Starter
Not sure how to read this Dyno sheet. Took my 2001 Cobra Vert to a local DYNO that was recommended by a friend. Paid $250 for a "DYNO Test/TUne". Was hoping someone from the forum can read and advise if the results are correct given the bolt on mods below.
*JLT CAI
*UPR Catted X Pipe
*Magnaflow Cat back
If you notice the HP Table reads "362.88HP". However, the line graph doesn't even hit the "300" mark. More like 280-285 or so. He said his inkjet printer was running out of ink - reason why blurred font reading. Seemed genuine enough.
Does 429.47 ft/lbs sound right?
Air/Fuel mixture?
Thanks in advance.
m109ner is offline
post #2 of 27 Old October 16th, 2012, 07:45 PM
WooMach1's Avatar
there is no way, they fucked up on something, 99/01 cobras stock put down around 270rwhp, with those bolt ons + tune your likely to get around 300rwhp and maybe about 310rwtq give or take a few. and when your do dyno run its bases from the rear wheels. Now the horsepower looks close enough to be right, but with those boltons you should be seeing your HP line REALLY close to 300 not around the 280 mark or they have no idea how to tune. as for the Torque... even though that would be awesome to have 429rwtq, your showing over a 100+ more that what your really should have. Your showing more torque outputs then boosted 99/01 cobras. Ive seen dynos showing both numbers being a little high or low if it wasnt SAE corrected, but NEVER have a seen on number be about 20hp short and then show torque being 120 higher.
If i were you, id complain to the dyno shop and tell them they fucked up
Mach 1
JLT RAI - MRT O/R HPipe - Borla - 4.10 Gears - 90mm LMAF
SCT Tuner - Eibach ProSport Springs - MM Lower Contol Arms
Baer Drilled & Slotted Rotors w/Hawk Pads - FR500 9"/10.5" w/Nittos
Exedy Mach 400 Clutch - Exedy Flywheel - MGW Shifter
WooMach1 is offline
post #3 of 27 Old October 16th, 2012, 08:07 PM
sgilbert8277's Avatar
NO FUCKIN WAY! No way in hell you're makin that kind of tq..
Thats with old shitty CAI that heat soaked like a mofo and plug blow out..
E Thug 4LIFE
sgilbert8277 is offline
post #4 of 27 Old October 16th, 2012, 09:11 PM Thread Starter
Yeah! After researching it and honking through it, I've come to the conclusion his is totally impossible and that they screwed something up. Maybe even, possibly, giving me someone else's dyno sheet. Maybe even, not uav
m109ner is offline
post #5 of 27 Old October 16th, 2012, 09:15 PM Thread Starter
...not even having done anything at all to my car. I'll gve the the benefit of the doubt as I challenged it his afternoon and he's supposed to send me the pull files early in h morning tomorrow.
I'm pulling multiple dyno sheets of 01 cobra verts with similar mods so I can prove to him he is wrong. Send like my A/F line is also incorrect. Should be more like 12.5:1 to 13:1.
Any similar dyno sheets to prove him wrong would certainly be appreciated.
Thanks!!!!
m109ner is offline
post #6 of 27 Old October 17th, 2012, 12:08 AM
gdl
I can't find the dyno sheet file but I have a printout from when we got our Mach1 tuned. The engines are very similar, the cams in the Mach tend to make a little more torque while the cams in your Cobra tend to make a bit more highend horsepower.
Mods are:
BBK Longtubes
BBK Catted H pipe
SSS Adrenaline catback
K&N CAI
PHP 3/8" intake spacer
Max power 319.87 @ ~5200 rpm
Max torque 332.08 @ ~4200 rpm
Torque curve is relatively flat. Showing ~260 @ ~2300 rpm, ramping up to 332 @ ~4200, staying around the 330 mark up to ~5000 rpm, then dropping off to ~240 @ ~6400 rpm.
Horsepower is a nice linear ramp up from ~140 @ ~2300 rpm to ~320 @ ~5000 rpm, then staying relatively flat to ~6200 rpm, then tailing off to ~305 @ ~6400 rpm.
I say your horsepower numbers look a little bit low, especially if they actually tuned your car. There is no way you're making 429 torque, you need a lot more cubic inches or a power adder of some kind to approach that kind of number. And yes the A/F looks way off. If you were really running that lean you'd likely destroy the engine in short order.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert - SOLD
gdl is offline
post #7 of 27 Old October 17th, 2012, 12:12 AM
Loud Exhaust Enthusiast
UDEAFBRO?'s Avatar
they probably pulled it in the wrong gear is my guess. either that or their computer is calculating wayyy off. Thats a 11 second car with those numbers man.
Originally Posted by TheUNZippee!
Dude if you had a vagina I would end you
UDEAFBRO? is offline
post #8 of 27 Old October 17th, 2012, 12:42 AM
gdl
Still can't locate the file that matches the numbers I just posted for the current mods but I did find another file from a previous tuning that more closely matches your configuration. This one is the Mach1 with the K&N CAI, PHP Intake Spacer, Magnaflow Catted X, and Magnaflow catback (not Magnapacks).
gdl is offline
post #9 of 27 Old October 17th, 2012, 12:52 AM
gdl
I think you hit it on the head, they used the wrong gear. I just noticed the OP's printout shows MPH instead of RPM for the bottom scale and it maxes out at about 110 mph. When I switch my graph to show mph it maxes at close to 135. That would have been with the stock 3.55 gears. Assuming the OP hasn't changed his he'd be running 3.27 so the max speed in 4th should be ~140. I think they did the dyno pulls in 3rd gear.
gdl is offline
post #10 of 27 Old October 17th, 2012, 12:56 AM
UDEAFBRO?'s Avatar
OP, bring the car back and ask them to do it again in 4th. Those torque numbers look way too high. The hp looks almost right at slightly below 300 but the torque is way off. Ask what gear they did the pull in man.
post #11 of 27 Old October 17th, 2012, 01:29 PM
termi_GT's Avatar
Most likely dyno calibration is off.
MM FOBRA CLUB CO-FOUNDER
termi_GT is offline
post #12 of 27 Old October 17th, 2012, 04:42 PM Thread Starter
****UPDATE***
Just got off the phone with the shop manager after a few unanswered calls and one Voice Mail. He said he did another DYNO this morning and the print outs were incorrect. He called his “computer guy” to come in and run some tests as he'd had this glitch before and his “computer guy” fixed it. Now I don’t know that I buy it, but I’ll give anyone the benefit of the doubt at least once. Shit happens…I get it.
In his defense, he promised to get back to me tonight or first thing tomorrow morning with a follow up after his computer guy gets everything fixed. He also said he just wants to make it right for me. He’ll tune and DYNO it again, if he has to (Yes, he will).
Moral of the story is, “Don’t just take your friends word on something, do your research 100% of the time”.
BTW- He does his pulls on 3rd gear and in STD Correct. You can believe I will request 4th gear pulls in SAE Correct…and I will definitely be there to witness the whole thing start to finish.
Anything I need to look out for or request when I take the car in again, please let me know. I want to go in completely prepared.
m109ner is offline
post #13 of 27 Old October 17th, 2012, 04:48 PM
Authorized Vendor
BMR Tech's Avatar
That does not appear to be a 4V N/A dyno graph, to be honest.
That looks more like a 100 shot 2V GT nitrous graph, or something nitrous injected.
The graph could be wrong due to a malfunction etc, but I am not buying it.
That curve just doesnt look right, regardless of the #'s.
FWIW, 3rd gear pulls will show lower numbers than 4th gear pulls.
BMR Tech is offline
post #14 of 27 Old October 18th, 2012, 12:25 PM
The hp and tq lines should cross at 5250 and these two do not and won't until around 8000rpm. Therefore the hp and tq graphs are from two different combos.
The hp graph is overlayed on the tq graph, note how they do not intersect:
na svt is offline
post #15 of 27 Old October 18th, 2012, 12:30 PM
Along with having the tune done in 4th gear, have the graph printed with SAE factoring and with the RPM, not MPH, at the bottom.
na svt is offline
post #16 of 27 Old October 18th, 2012, 12:34 PM
Originally Posted by m109ner View Post
****UPDATE***
This is crap, to print a dynosheet you first open "WINPEP" and then the specific .drf file. It's like opening MS Word and then a specific word document. There's no way that it can open and merge two files at one time.
na svt is offline
post #17 of 27 Old October 18th, 2012, 12:39 PM
^ +1
I think This guy is dicking you around.. If you do let him re-dyno your car stand next to the computer. You'll see your run on the monitor, no way for it to get "messed up"
E Thug 4LIFE
post #18 of 27 Old October 18th, 2012, 01:27 PM
Send a message via AIM to mikeracing
^^^^ def. agree and it would make the tq and hp way higher
and about the 3rd gear with most 4 speed auto's 3rd gear is 1:1 so if they dont do much work with stick cars i could see the f$#@ up but the operator should have known something was up when the car made those numbers without being a bb
mikeracing is offline
post #19 of 27 Old October 18th, 2012, 01:39 PM
This is false, dynoing in 3rd gear results in lower numbers.
na svt is offline
post #20 of 27 Old October 18th, 2012, 01:52 PM
Priest of the Car Gods
ReverendDexter's Avatar
If your peak hp is lower than your peak torque, that would mean that your peak hp is happening below 5250 rpm, which is most definitely not the case with most gas DOHC motors I'm aware of, certainly not with any 4v in a Mustang.
EDIT: Apparently the 5.4 out of the Navigator has peak hp below 5250, so I was wrong there and changed my above statement.
Function > Form, always
ReverendDexter is offline
Human Verification
