Did I Blow A Head Gasket?
Old July 27th, 2006, 09:12 AM   #1
red01's Avatar
red01 is on a distinguished road
I have a huge oil leak that is coming from above the exhaust manifold on the drivers side. the valve cover gasket is dry. Its leaking from above the header and dripping down onto it. I did spray the car the night before. The car drives normal, starts fine, and runs like it always did, but is losing oil bad from that spot. Any ideas?
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
Old July 27th, 2006, 11:08 AM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Cracked head?
Hope not
Classic Mustangs are the best! Get one.
Old July 27th, 2006, 11:57 AM   #3
red01's Avatar
Originally Posted by Horseshoeing
Cracked head?
Hope not
Dam I hope not either. The wierd thing is that the car runs fine. It has oil pressure and its not over heating, drives like it always did.
1997 Mustang GT
255/292
Old July 27th, 2006, 03:58 PM   #4
Classic Moderator
Maybe the valve cover gasket is leaking . I don't know those cars , but could it be something like pcv valve hose has a hole and is blowing on it.
Old July 27th, 2006, 05:52 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Do a compression check and a cooling system check. You will know real quick what is wrong.
Old July 28th, 2006, 10:29 PM   #6
red01's Avatar
Found the problem. Turns out that the mechanical oil press. guage I have got a hole in the cheap nylon tubing that they give you. It was squirting out of that line and landing on the header giving the illusion that it was leaking from around that area. Thank god it was something stupid.
1997 Mustang GT
255/292
Old July 28th, 2006, 10:41 PM   #7
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Close call on that one.
Threads Similar to: Did I Blow A Head Gasket?
blown head gasket 5.0pwr 96-98 2 September 17th, 2007 11:57 PM
Head gasket nasty92LX 5.0 Mustangs 9 September 13th, 2007 04:25 PM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 10:48 PM
99 3.8 L Head Gasket? Mike s V6 Mustangs 11 November 13th, 2006 03:51 PM
head gasket cali 5.0 5.0 Mustangs 3 June 20th, 2006 03:33 PM
