downshifting to 2nd gear
Old August 17th, 2006, 05:36 PM   #1
cobralini is on a distinguished road
My trans seems to be doing fine until I try to downshift into 2nd gear. Sometimes if I go back to fifth then it will slip into 2nd. What can I do to cure this besides not downshifting.
Old August 18th, 2006, 12:12 AM   #2
try adjusting the shifter if an aftermarket shifter, If that ck's out ok, replace the 1-2 syncro
88 Mustang Coupe
www.rickscarcare.net
Old August 18th, 2006, 12:38 AM   #3
phazedragon is on a distinguished road
I don't have that problem but mine is upshifting to 3rd gear every now and then it just won't go into gear and if it does it grinds a little but after that it will fine for a little while and then act up again i was thinking about the syncro but to fix it it is 900.00 cdn and i am on the lookout for a t-56 trans
Old August 22nd, 2006, 09:06 PM   #4
Milner62 is on a distinguished road
On my 88 ford escort gt if i shift from neutral into reverse it grinds, but if i shift into first then shift directly into revrese afterwards it dosent grind. Not sure what it is, but check the linkage if it dosent want to seem to go into gear it might not be engaging it fully.
Old August 22nd, 2006, 11:29 PM   #5
stang fanatic's Avatar
stang fanatic is on a distinguished road
Thats a clutch issue there, its because the mainshaft hasnt stopped spinning...your clutch is dragging when the pedals pushed in
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 23rd, 2006, 05:09 PM   #6
Well it dosent always grind cause ive gotten used to shifting into first then reverse. Plus Im not sure if the clutch is gone cause the cluch dosent have but 80,000 miles on it. Anyways Id check the linkage to see if its fully engaging the gear
Old August 30th, 2006, 05:48 PM   #7
Do you think doing a drain and refill will solve my problem ?
Old August 30th, 2006, 10:42 PM   #8
probably not but for less than $10 it can't hurt to try.
88 Mustang Coupe
Old September 22nd, 2007, 09:07 AM   #9
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
mine grinds in reverse too....
Originally Posted by Cesar2cool
lol i use my car for speed
Old September 22nd, 2007, 03:16 PM   #10
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
AHAHAHA 232 bumped the year old post today
But this is a common problem for manual trannys with the clutch in put it in fourth then reverse it wont grind after that
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old September 30th, 2007, 11:09 PM   #11
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
1+
Threads Similar to: downshifting to 2nd gear
best gear for my set up 1BADSTANG 5.0 Mustangs 14 September 30th, 2007 08:57 PM
automatic downshifting... Murderjetz V6 Mustangs 4 August 6th, 2007 07:27 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 06:22 PM
downshifting myroush6 2005 - 2010 32 March 22nd, 2007 02:22 PM
7 tooth drive gear or 8 tooth drive gear for my 98 GT manual Blue98GT Modular Mustangs 1 January 6th, 2007 08:27 PM
