need help 03 cobra charging problem
I have a full build cobra i cant seem to get it to charge I got the batt in the back with 0 gauge +/- wiring bought two new alt the new alt checks out good but if I let the car run for about 10-15 mins it will die or if i pull the + off it will die i did a volt check 13.4 with the car off start the car it drops to about 10.8 -10.6 what is the charge wire on the alt ?
#2 | |
2002 Ford Focus
slow as fuck
![]() iTrader: 4 reviews
99 V6 Mustang-sold 02 Ford Focus-sold 98 Camaro Z/28-lid, catback |
new engine wiring harness
yes it does have 1148 hp at 27 psi on oxygenated fuel from vp I went ahead an bought a new engine wiring harness from ford going to see if that helps if not i give up i will keep ever one posted i will try to get vid of the car on the dyno my buddy was the one with the cam I haven't talked to him for a few months
My street tune is for 93 pump 15 psi 18% 780hp thats is a super safe tune there is alot more power if i wanted to have them mess with the timing the car looks 100% stock no cage no mods to body
#5 | |
also check the wires on the alt to make sure they are hooked up correctly and follow the field wire from your alt to you battery to make sure that it has no breaks in it
Threads Similar to: need help 03 cobra charging problem
| Charging Problem On My Fox Body | juggalowelder | 5.0 Mustangs | 24 | December 24th, 2007 12:17 PM |
| charging help! | pnyboi | 5.0 Mustangs | 3 | May 7th, 2007 07:54 PM |
| UD Pulleys Rob Charging System? | Finegan | 2005 - 2010 | 4 | April 17th, 2007 02:16 PM |
| Charging problem or battery | shadowgames81 | 5.0 Mustangs | 12 | January 13th, 2007 03:34 PM |
| Charging Problem... Please Help! | cstmp8r | Audio/Video | 3 | November 13th, 2006 02:47 AM |
