#21 |
Gun Whore
04 Whipple Cobra
10.61@129.96
ill ask him about the ice thing.
he used a bigger pump, the stock pump wont support pushing the volume to the trunk, the stockers just a little baby thing. leaded gas will shorten the life of you O2's yes, but not that bad. they will still last 1-2 years. just dont run leaded all the time, and youll be fine.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
#22 |
i was thinking if i run
5 gals of 93 and 5 gal off 117 what the hell would that be ? the 104 i got is unleaded. so if its not going to be over 104 its not worth it . or i could use 5 gals of 117 and 2 gallons of 93? i run 117 straight in my 83 gt. |
#23 |
Gun Whore
04 Whipple Cobra
10.61@129.96
you would probably be ok with 104 octane.
#24 |
the 104 is highly oxgyenated so rick had to tune it to that gasa cause it takes more fuel to make it richer i think?
so you thinnk i need to keep my bap. ? im going to be getting that 5.0 mod block to build. im ws planning on using the stock heads , and cams on it , with just the more cubes. but if im going to need a rotating assy also , so i dont know of i should strok it while im at it , and just run the 19 psi i got now would put my over 700 right , even if i didnt go 5.0 stroker right . so i should keep tha bap. imy buddy call yeaterday ans wanted to know if i was going to sel it to him or not ? |
#25 |
Gun Whore
04 Whipple Cobra
10.61@129.96
if your going to build the motor you mgiht aswell do heads.
i would just order a completely built shortblock from MMR you can get the 1150 which will support 1100HP, and is a 5.0L for $4K, it has billet I beams, and everything. i would get a set of revised fed 05 heads that dont have the flow issues and send them to fox lake to be ported. that and a set of stage 2, or 3 SC cams, and your set. then you can sell your stock bottom end for $2000, and your heads for $1000.
#26 | |
Threads Similar to: Gt Pumps Limits? Rwhp?
| RPM limits of a stock 4.6. | ModMustang97GT | Modular Mustangs | 31 | January 7th, 2008 05:46 PM |
| tranny hp limits question | Plays With Squirrels | 96-98 | 3 | August 4th, 2007 05:04 AM |
| v6 motor limits | popmyclutch | V6 Mustangs | 6 | July 7th, 2007 01:41 AM |
| What pumps do I have??? duel pumps, see pics | jdslyrbullitt | 99-04 | 1 | February 26th, 2007 10:16 PM |
| Limits of the 4.6L 24 valve motor | OcOnnor220 | 99-04 | 11 | December 31st, 2006 03:06 PM |
