Need Drag Wheels !
ok i got a 97 cobra SRA. with cobra brakes what is every one running like
15x10s in rear? on 6.5 backspace? for fronts i dont want 3 inch rims at leat 5s or 6s. will this clear the brakes ft. and rear ? i think i need spacers for the front ? right the rear i dont know that offset for sure. i'll be running 27x11.50x15s hoosier quick time in rear. not sure if i got to run spacer in rear or get gt brake to clear , someone steer me right . i want a set of drag wheels |
Gun Whore
04 Whipple Cobra
10.61@129.96
on the rear you will want a 6.5" backspacing, and a 15X10. since you have the 97 housing you could go with a 6" backspacing, but 6.5 will still be fine.
for the front get 15X3.5, or 4", and you will have to use a 1.25" bolt on spacer up front to clear the cobra brakes. if you want to spend like double the $$ of welds though, you can get bogarts in 16" with a made on spacer that will clear the front brakes, you will jsut have to install longer wheels studs.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
#3 | |
i dont 3s ar 4s in the front . maybe 5s ,3s are to shinny cause ill be driving aorund town on them also. my other set wil be for long high use witht e pump gas tune, i fuguied i was going to spin anyhow with the nitto's plus car will be alot lighter too. i can get a upr ft. k member with the shock/spring set up and lower control arms for 550 shipped? are 350 lb springs on the front enough. my 82 has 175s i think ? |
Gun Whore
04 Whipple Cobra
10.61@129.96
get 3.5's in the front, and run a 4, or 5" tire. a 5" rim you'll have to run a 7" or so tire on, and will add even more weight, biggest thing about big n littles is the weight reduction. they drive fine around town too, jsut dont do a mario andretti around a turn.
look into pics of draglites on these cars, they really dont look good. the prostarts look great though. i think the $550 deal on the UPR K member is up, i think its back to $700 now.
the upr k meme on svt is sold i waited to long , im trying to drop some weight , i already lost 160 lbs withthe SRA swap i weight everything on it , and went on it , came to be 160 lbs saving , i think another 75 is with the ft. m kmemeber right > with out using the big heavt stock springs right ? . ill be adding some with the 6 pt bar too.
i got weld on my 83 look good rear trims ans tires wiegh 35 lbs i like compard to my 75 lbs.ers. im thinking of the k memeber rally witht eh welds. the pro stars look ok? you can see more of the rotors and brakes ..right ? i want to run some 10.0s with my vert?> is that possible im going to be fabing my up a 5 gal ice box for my inter cooler i need to put a temp gauge on the output side of my inter coller to see what the temps are? is that a good idea? to record them b4 , that do the 5 gal ice box with my same set up to see the temp drop in how fast it rise's or do you thinkn a 12 gal in the trunk would be better ,,thats a lot of heater hose x2.i did fins some extra pumps i got some off some mercedes i work one it the same size , it for moving more water though the heater core at idle i could run 2 of tham on a seprate switched circut. it has 5/8 fittings .it only draws 1 amp per pump.or i could go 5 gal and mt inside of car. what you think? |
Proud American
3.5 inch Skinnies upfront are fun to drive on the streets. And get a 6.5 back spacing in the rear with a 1.25 inch spacer upfront.
i dont want 3 inchers on the front need 5inches. i dont like the bike tires one the front.
this is what i do want this is my 83 gt with the 408w i just waxed that dudea ass , hes pissed LOL 10.09 at 138 1.44 60 fts
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
KC is right. Dont put draglites on your cobra. They really dont flow with the new edges all that good. Get yourself some prostars or telestars and be done with it. They look fucking sweet.
I just want to say this thread is awesome as I was in the same market for my 1996 Cobra. I want 15" Weld Prostars, but didn't know the sizing or backspacing.
Would all those measurements be the same on a 1996? Will a 10" even fit back there with the shocks, etc? I think the 99-04 can house a bigger wheel for some reason. |
what are tele stars?
so you dont like the drag lite looks ,post of the 3 rims if anyone got pics , on the car of course .. u se to be a bogart back in the day LOL |
Your number was 666... I'd never wash that off my windshield.
that was a good # that day
allmotor 11.26/124 ............11.23/124 200 shot 10.36 10.19 10.09 10.09/138 1.44 60 fts. i havent run it in 2 years , 80 miles on 408w motor tko trans 3.73s 11.6 compression victor jr heads .700 lift solid roller cam 1000 demon carb another 50 shot is possible turn key and run 10.0s for $14,000 ill throw in the a/c stuff with that price. |
2003 SVT Cobra
11.70 @ 121
telstars
![]() prostars draglites |
that is my buddies white cobra at the very top of yhour post weems. its a good looking car and is currently getting a new badass 4v put into. should make close to 700 rwhp on the spray
2003 SVT Cobra
11.70 @ 121
holy shit, why didnt he sell it?
Man... that thing reminds me of my 84 GT... should have never sold that car.
i got it new in sept 83 with 8 miles on it for $10,100
now its got 178,XXX on it the last 8 years only 1300 miles been though 3 rearends 4 trans 6 motors and hell at least 8 heater, and a/c cores. |
Threads Similar to: Need Drag Wheels !
| Wheels come off a drag racing Chevy Camaro | trev0006 | Videos | 4 | January 10th, 2008 03:30 PM |
| Wheels for drag radials? | fomocoro | 2005 - 2010 | 1 | April 10th, 2007 06:00 PM |
| Drag / Street Wheels? | MyStang02 | Drag | 3 | November 6th, 2006 02:26 AM |
| Need some help finding some Wheels and Tires for Drag Racing | L33T | 2005 - 2010 | 3 | August 6th, 2006 09:16 PM |
