1992 LX 5.0
termi wheel hop
I have a buddy with an 04 Cobra with a few bolt ons. He's having wheel hop, as I assume all of the irs cobras do. I've read that you can replace the control arm bushings to reduce/eliminate this.
Maximum motorsports said they recommend using bushings made from "delrin" instead of polyurethane, as the urethane ones still deflect and don't completely solve the issue. Anyone have any luck fixing the wheel hop issues with the IRS, or does everyone just do a single axle swap? |
2002 Chevrolet Impala
derlin might not be very fun if it's a dd
2003 GT/ 4v Swap
I have herd about a brace that you can buy for them that helps but I dont know what it is called. I think the 2001 Cobra R has it on stock.
2003 GT 1999 4v swap Full Bolt ons |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
from what i have read you can completely build the irs for big $$ and it helps out alot but does not eliminate wheel hop. tell your buddy to do a sra swap
Gun Whore
04 Whipple Cobra
10.61@129.96
the best 2 single wheelhop mods are a set of FLSFC's, either MM, or steeda, and then soem drag radials.
Modded Mustangs Make-A-Wish for Bubba "BWAL09" [url]http://www.moddedmustangs.com/forums/clubhouse/112652-hey-guys-mm-needs-unite-bubba.html[/url] [QUOTE=Drgnracin72;1870015]please do this country a favor and go play tag football with an oncoming car[/QUOTE] |
2004 Cobra
Changed all the bushings, added braces ect. - helps out but does not remove it all together.
1992 LX 5.0
he's got full length subs and used nitto drag radials (i know they suck, but came with the car)
his wheel hop was more pronounced with drag radials. I think he's leaning towards keeping the IRS what kind of brace did you add import? |
Nittos are actually pretty good. drgnrcn almost got his front tires off the ground with a little over 300 rwhp on nittos.
2001 svt cobra
no way (IRS)
SRA why than you would be just like a **** 1, JK
Build #1249 MM New Edge Crew Member# 6 |
2004 Cobra
Rear end support brace. Just some prev. maint. thoughts.
1999 COBRA
check this out.
ford whoops.... my bad. COBRA OWNERS NEED TO READ!! also when i got my 4.10's put in i had them swap out my diff mounts from the stock rubber to maximum motorsports poly ones. that did WONDERS for my wheel hop. i think the bushings where only like $45 too. i could have done the swap my self but since they were already down there it was easy for them to do it. heres th link.... Maximum Motorsports :: The Leader In Mustang Performance Suspension its in the cobra irs section under diff mounts.
![]() Pyps catted x, super 44's dumped, K&N filter, FRPP 4.10's, xcal 3, Maximum Motersports poly IRS bushings W/ 14mm bolts, poly motor mounts, 2003 cobra wheels and headlights |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
Gun Whore
04 Whipple Cobra
10.61@129.96
#15 | |
Gun Whore
04 Whipple Cobra
10.61@129.96
the next step if he has FLSFC's, and DR's is the subframe bushings, MM is the only way to go for them. also he needs to make sure he has a IRS brace ont he pumkin, it wont eliminate any hop, but will keep him from busting the pumkin.
One Man Wolf Pack
FLSFC = Full Length Sub Frame Connectors
![]() ΜΟΛΩΝ ΛΑΒΕ
1992 LX 5.0
halfshafts broke today
Gun Whore
04 Whipple Cobra
10.61@129.96
hop kills
Gun Whore
04 Whipple Cobra
10.61@129.96
yup, gotta get rid of it. most people break stock halfshafts, and think you need them by 500RWHP, or mid 11's, and thats false, with all the bushings, and proper 15" tires, not 17"DR's stock shafts will go mid 10's no problem. most people are just idiots, and go to the track with 17's, and no matter what tire, its going to hop. it can kill solid axles just as easy as halfshafts.
Threads Similar to: termi wheel hop
| termi bumper? | mystang0673 | 99-04 | 10 | November 26th, 2009 02:10 PM |
| WRX vs Termi | 9cobra3 | Modular Mustangs | 21 | November 14th, 2007 12:41 PM |
| Cobra vs Termi | AnglicoGT98 | 99-04 | 30 | November 1st, 2007 08:53 PM |
