2003 Cobra
12.3@ 113
Cobra alternators going bad
Anyone been having problems with 03-04 Cobra alternators going out? My friend's died at about 50k miles and mine just bit the dust at 60k. Im wondering if I should just get a new or rebuilt Ford unit, or go to a better one like Bosch or Mean Green. I dont want to buy another one in 50k miles. Also, I know a place that will rebuild mine for like $75, anyone have experience with getting theirs rebuilt?
2003 Cobra
12.3@ 113
also, I do have one hell of a stereo in the car pushing about 1500 watts rms, but my friend's is stock, and mine lasted longer than his.
N/A 4v Guru
2003 Mach 1
1500 watts is not that much. Are you running a bigger lower pulley? That can spin them faster and wear em out quicker.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2003 Cobra
12.3@ 113
no, all the pulleys are stock
can't say i've heard of ford having problems with their alt. but if you guys want to try and save some money you could rebuild it your selves for about half of what it cost to buy new.
High Output Alternators,Alternator Parts, High amp alternator, Chrome Alternators,Quick Start Rebuild Kits, alternator part you'll have to look around a bit, but it should be in their. i just rebuilt mine after 80k. |
2003 Cobra
12.3@ 113
thanks cmr98 for the info, I'll check it out
#7 | |
![]() My first one was around 40,000 miles. my extended warranty covered both replacements. Replacing the battery isn't covered and both times my battery was so drained it couldn't be charged.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
#8 | |
2003 Mustang Cobra
Also, doing lots of racing, at real high RPMs, might effect the life of your alternator. |
#9 | |
2001 Mustang GT
UNKown
you must be use to the 1000 watt 1"x2" amps from walmart.
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2010 |
2003 Cobra
12.3@ 113
Yeah, its about 1400-1500 rms. The Rockford sub amp (old Power 800a2) came with a "dyno" sheet when I bought it. It made 1054 watts RMS bridged into 2 ohms. It is running a JL Audio 12 W7 so it is running at 1.5 ohms. Therefore the output should be a little higher. I also have a JL Audio 300/4 amp that is 75w x 4 (300 watts RMS). My friend's car has the stock stereo though. I think the extra heat of the Cobra motor and the fact that the alternator is buried on the side of the motor probably cuts its life short. I work at Autozone so I just bought one of the remanufactured alts. from there since it was cheap and has a lifetime warranty. So when it dies again (as I'm sure it will) i can just take it up there and get a new one for free!!
2003 Cobra
12.3@ 113
And 1500 watts RMS is a lot for someone who just wants a loud stereo that sounds great. It might be nothing compared to people with Suburbans that have 8 subs, but 1500 watts RMS can pretty much run (and do it well) anything you could stuff in a Mustang's trunk (and still retain the space required for a daily driver).
My 04 Snake only has 9,000 miles on it, and I have gone through 2 alternators already. And currently needs another.
Previously I have used Ford parts... this time I will be trying a NAPA model instead. Only mods currently are the 2.76 upper, and full set of billet-flow idlers. Car is dead silent for about 500 miles after the alternator is changed, then it starts chirping again at startup. Turning the alternator by hand, you can feel it bind at a certain point. I am beginning to wonder if it has something to do with the extremely tight belt pressure we run with the smaller blower pullies (damaging the rear-bearing in the alternator)? Rod |
Saving up for another one
yeah, alternators going out early is common with the 03-04 cobras.
2003 Mustang Cobra
yeah mine went out at 93k. Rebuilt by a reputable shop, and didnt even last a thousand miles. so i went with a lifetime warranty from Kragen, autozones close competitor.
![]() MM Cobra Club Member #28 |
First time mine went out i went with a PA performance alternator thinking i wouldn't have to worry about for awhile. Wrong it didnt last as long as the factory alternator. This second time i went with a OEM unit and its been doing fine since
It's because they're overspun. If you're blowing alts left and right, get a larger pulley from Metco.
Threads Similar to: Cobra alternators going bad
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 14 | February 19th, 2012 09:19 PM |
| Cobra R brakes with 2003 10th anniversary cobra wheels...? | Gen1sve | 99-04 | 11 | August 31st, 2011 11:57 PM |
| 1996 cobra swap with 03 cobra heads and supercharger. | stan's96snake | 96-98 | 14 | October 30th, 2010 03:57 PM |
| Newbie question. 98 cobra with 99 cobra tranny...Speedo fix? | RoyalCars | Modular Mustangs | 5 | February 18th, 2007 10:17 AM |
