GT 500 Heads
Are the GT 500 Heads the same as the 03/04 cobra heads or are they bigger? Anyone know? If so can they be put on 4.6 liter blocks?
N/A 4v Guru
2003 Mach 1
They are basicly FR500 heads like where used on the 2000 Cobra R. The exhaust bolt pattern on the head is different on the shelby head than other 4v heads so header selection will be kinda tough. Probably just run shelby headers but I am not positive about fitment. Also the intake ports on the shelby head are raised, so you will have to run a custom manifold or get some adaptor plates to make your stock one work. Thats basicly the jist of it.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
Are they worth the trouble you think?
N/A 4v Guru
2003 Mach 1
Not on a 4v car thats a 99 or newer.
+50000 If you have a 99+ cobra or a Mach then thats your best bet. It will be easier and cheaper. The 03-04 Mach/Cobra heads aren't very much below the fr500 heads. Having said that if you wanna change heads thats the heads to shoot for. They are cheaper, easier to get, and are a direct bolt on for a 4.6 4v.
Ok sounds good.
how big of a difference is there between the Ford GT heads, and the 03/04 heads?
1998 Mustang GT
Need to hit the track
wouldn't the Ford GT heads be a 2V heads?
No, the Ford GT as in the supercar....not the mustang GT.
2007 GT500
The Ford GT head is the GT500 head.
The cam, blower, and block are the main differences. |
^^^ wouldnt it be that the GT500 head is the Ford GT head since it came out first?
2007 GT500
Okay
You got me. |
Threads Similar to: GT 500 Heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| 4V heads Vs 3V heads, and noob Q. | TheUNZippee! | 4V / SVT | 19 | February 5th, 2008 03:17 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
