cobra engine
whats better an 2001 cobra engine or a 2003 cobra engine
Priest of the Car Gods
yeah, the only reason to not say '03 would be for the iron block.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
03 10th Ani Cobra Vert
12.20@115
of course the 03... forged internals... lower compression which means more PSI = MORE POWER
define better, 2003 is forged, but the internals are nothing special... and the cobra heads arnt as good as the 2001 heads if you ask me.. but thats factory tuning for use with the supercharger. the m112 is crap... ok for the average guy, but not nearly enough for me, the 2003 motor have head tick problems.. they have to be replaced at 1500 a piece to you. The motor is overall good, the head cooling mod is an absolute must (helps with the tick) I am a modder, so stock anything is worth nothing to me... if your going to heavily mod your car, your better off with a GT or a v-6 and gut it, if your gonna do bolt ons and piddly stuff then the cobra is worth it. but imo there is no sense in paying alot, just to turn around and pay alot more (cobra parts are more expensive to work with other stock crap)... the tranny is not viper spec, it has IRS - which I like but isnt superior by any means for performance.. the brakes are upgraded but dont perform all that well, nice body.. but cheap to buy on your own also... and then the cobra is worth more, but when you modd it, its worth less...
In all your better off buying an 01 motor, forging it and gettin the heads worked for about the same price a stock cobra motor
Considering selling my car to fund my race car: take a look and tell me what you think. http://www.moddedmustangs.com/forums...ml#post1041280 |
2001 svt cobra
no way (IRS)
Build #1249 MM New Edge Crew Member# 6 |
actually higher compression means more power there champ, just detonation can rain on your parade
and less "psi" as you put it
#10 | |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
get a 01 without forging the internals and run a kb with 15 lbs = boom 03 cobra with kb 15 lbs = 550+ hp 03 > 01 |
he said lower compress means more psi ... it doesnt
and 01 motor $1500- add 3-4k in work... a hell of alot better than a stock 03 03 motor $5000 or more
that black and white scheme is sick
Not directly, but lower compression means you can run more psi without bad things happening to your engine.
ya dont say.... really?
c'mon man we should be above stating the obvious
N/A 4v Guru
2003 Mach 1
The fact that you think the 01 heads are better is misguided. The fact that you think the terminator bottom end isn't anything impressive is misguided. Pound for pound the terminator will hold more than a built 01 will.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
1999 SVT Cobra
13.43
go 03, i wish i had the money to get one
Threads Similar to: cobra engine
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 13 | March 1st, 2011 11:45 PM |
| cobra engine | bluemustang04 | 4V / SVT | 15 | March 20th, 2008 09:18 PM |
| 07 Cobra Engine In My 07 GT ? | TDog | 2005 - 2010 | 32 | November 17th, 2007 02:56 AM |
| no ECU with cobra engine? | Invictus | 99-04 | 3 | April 2nd, 2007 09:26 AM |
| Cobra engine | laserstang2 | 96-98 | 14 | February 22nd, 2007 12:49 AM |
