Second Gear Grind?
Old April 9th, 2008, 11:57 PM   #1
MM's Ford Truck Guy
FX4DTUF's Avatar
99 ranger,2010 ranger
does nice burnouts
FX4DTUF has a spectacular aura aboutFX4DTUF has a spectacular aura about
Second Gear Grind?
Ok so i was out driving my mach ok and i come up 2 a light and shift from 3rd too 2nd and it wont go in so i push the clutch all the way in and it finally clunks in and i was like thats weird... so i come of the light try 2 shift into 2nd @ 2500 and it grinds then goes in and it did it again and agian so i shifted into 3rd the rest of the night on my way home and i tryed it and if you hold the clutch all the way in and give it 2-5 seconds it will go in perfectly but if you shift it regular it grinds then goes in???? any sugestions maybe a servo and the wierd thing is it will stay in second and not pop out like normal servo's when they go bad ?????? HELP...
1999 xlt 2.5 ranger lowered 5/6 on 17in bullits
2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits
Old April 9th, 2008, 11:58 PM   #2
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
i will catch up with the post 2morro jus give me your input i got 2 be at work by 6 like every morning so i'll catch up with it later thanks
Old April 10th, 2008, 12:04 AM   #3
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
bump so i can get feedback b4 i go 2 bed
Old April 10th, 2008, 12:11 AM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
It's been 6 minutes since your last post. It's not going to move off the first page for the next few days.
360HP / 345TQ N/A
Old April 10th, 2008, 01:08 AM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Probably synchro. Holding the clutch in allows the input shaft to slow down which is why it is easier to get it in if you hold the clutch.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old April 10th, 2008, 01:31 AM   #6
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
synchro, same thing happend to me..
Old April 10th, 2008, 01:41 PM   #7
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
synocros. Same thing happened to me. I had to replace it in mine it grinde and broke during a race.
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old April 10th, 2008, 05:45 PM   #8
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
damn i knew it. it was weird like i wusnt even roomping it and it jus grinded and then now it jus grinds all the time how much are they arnt they like 60-80 dollars from ford and like 100-150 for a carbon fiber racing sencro
Old April 10th, 2008, 06:33 PM   #9
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
should i drive with like that or am i gonna have 2 drive the danger ranger friday and the weekend
Old April 10th, 2008, 07:11 PM   #10
2002 camaro
camarojunky74 is on a distinguished road
before you call it quits maybe i can help, this isnt a t56 correct?
i believe you are rocking a 5 speed if so, and the problems your stating i would say that there is a possibility your hydraulic system for your clutch has a problem and or has had a problem this is why the tranny is reacting the way it is,
try bleeding your clutch and making sure full disengagement is achieved when you put the pedal to the floor, if you check that is working perfectly try changing your tranny fluid to gm synchromesh,
i have a 98 ranger and the same thing was happening to me until i changed the fluid and wha laa problem solved,
also let me guess the hotter the trans gets or the longer you drive the worse it does it right?
probably fluid deterioration.
hope this helps. good luck
Old April 10th, 2008, 07:13 PM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Poor camaro guy.
Mustangs have cable clutches.
Military Crew
U.S. Army Aviation
Old April 10th, 2008, 07:21 PM   #12
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Which can be part of the issue - if the cable is stretched, the stock quadrant may not be disengaging the clutch completely.
I honestly think the issue is synchros, but I figured I'd toss that into the fray.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old April 10th, 2008, 07:25 PM   #13
2002 camaro
Originally Posted by Doc8224 View Post
Poor camaro guy.
damnit, well at least 95% of that post was helpful.
give me some time, there is only so much i can know about the enemy lol
Old April 10th, 2008, 08:36 PM   #14
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
talk to me lol..
Old April 11th, 2008, 01:19 AM   #15
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Tell me about it. I just learned the other day that the Camaros only have one cam. Damn you all and your cheap parts for big gains.
360HP / 345TQ N/A
Old April 11th, 2008, 01:25 AM   #16
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Military Crew
U.S. Army Aviation
Old April 11th, 2008, 01:15 PM   #17
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
haha this is funny check my fluid system haha man i seriously lol'd but yeah do you guys think it might help if i adjusted my clutch but i still think its a sencro goin
Old April 11th, 2008, 08:40 PM   #18
2002 camaro
lol, well some call it old school, but i say if it aint broke dont fix it, kinda like when ford went modular in i think 96, you can pretty much kiss all n/a power goodbye, stock that is, and i know the mach 1's are damn fast for being n/a and only 4.6 but that motor can breathe.
but yes, a 16v pushrod motor is what all ls motors are based off of, with slight differences between years and models as far as casting #'s but everything is intechangeable, so if you find a zo6 vette guy going for bigger power, you can buy his stock heads, mill them port them, throw in a small cam and your sitting at anywheres to 400 hp all the way into the 5's depending on what size cam and how much work you pour into the heads,i know my buddy has ported ls7 heads on his ls2, and they flow 385cfm at 600 lift, you cant find that shit even from afr, he's got a 10 sec pig, aka gto,
Old April 13th, 2008, 10:55 AM   #19
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
check 4th gear..see if it grinds at all..synchros work in groups 1st,3rd,5th and then 2nd,4th, and Reverse..to check your clutch put the e-brake up put it in first gear, then slowly let the clutch out and it should want to stall right around half way up..
Cohagan Engineering, Inc.
Old April 13th, 2008, 01:36 PM   #20
MM's Ford Truck Guy
FX4DTUF's Avatar
does nice burnouts
ok ill try that 4 shure but the only gear that grinds is 2nd
Threads Similar to: Second Gear Grind?
3rd gear grind... zinc02GT 99-04 28 March 18th, 2008 07:48 PM
3rd Gear Grind? PonyXpress 5.0 Mustangs 1 December 14th, 2007 02:42 AM
3rd Gear Grind? PonyXpress 99-04 5 December 5th, 2007 01:44 AM
5th gear grind on 5 speed emgjsdk1 V6 Mustangs 9 August 22nd, 2007 06:54 PM
