cast or aluminum block
Old April 10th, 2008, 11:24 PM   #1
compgun's Avatar
1997 Mustang Cobra
compgun is on a distinguished road
I want to build a new engine for my fun toy .I need help on what block to use.I do not want to use the one in her, I want to keep it as back up. I want to get up to 700 - 800 hp. Drag and auto x racing but streetable. Should I use a new cast block or a used Teksid aluminum block like I have now?
97 Cobra
Borla Cat-Back
Spec Stage 3 Clutch
Steeda Tri-Ax Shifter
Bullitt Rims
Lower springs
Rear Upper and Lower Control Arm
3.73 Gears
100 shot Nitrous
Old April 10th, 2008, 11:30 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Teksid block. Less weight and unless you are gonna go past 800 you won't have to worry about it. The teksid should hold you past the 1k mark.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old April 10th, 2008, 11:53 PM   #3
JStang14's Avatar
JStang14 is on a distinguished road
+1 the teksid block is by far the best block to build off of
Old April 11th, 2008, 12:07 AM   #4
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
+2 on the teksid
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old April 11th, 2008, 12:17 AM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
And a semantics issue - cast isn't in opposition to aluminum. Cast is a process to make the block, aluminum is the metal the block would be made from.
Yes, I'm *that* internet asshole.
And I'd say Teksid, just put forged internals in it.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old April 11th, 2008, 12:20 AM   #6
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
Teksid.
I don't think you thought any of this through.
Not only is a 800hp built Teksid motor expensive, but building a car that can handle it safely will cost a bundle. Transmission, internals, forced induction (you'd probably be looking at a turbo setup), custom exhaust, proper chassis modifcation, suspension, roll cage, harness...
On top of this you want to drag and autocross it and still drive it on the street? Your "backup" motor to your 800hp monster would be your stock... 305 crank HP Teksid motor? You do know 800hp would put you well into the 9 second bracket and some, right?
Old April 11th, 2008, 12:25 AM   #7
Heh, I didn't read that... 800 hp, drag, auto-x, and streetable. Honestly, these things are in opposition.
My suggestion - take all this money, get a full MM race suspension under your car. Then talk about 800 hp.
O o
\_\
Old April 11th, 2008, 01:13 AM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Streetable 800 is not too hard to do. If you are using a turbo setup just go with a digital boost controller, and dial it back for DD purposes. As for drag setup vs auto x setup. It all depends on how hardcore you wanna go in either direction. With fully adjustable shocks/struts and coilovers up front, along with the other supporting suspension mods its not too hard to accomplish. However, if you wanna be setup perfectly for either one then you will sacrifice the other. I have seen plenty of terminators running around with 6-800 hp and they DD them as well. What he is trying to do power wise is not gonna be the issue, its deciding what he wants to do with it and what he is willing to not be able to do with it because of that. It is a very expensive project but its not insane.
Military Crew
U.S. Army Aviation
Old April 11th, 2008, 01:15 AM   #9
1996 Ford SVT Cobra
13.36@102
No, it's not insane and it is possible. How many of these threads follow through?
Old April 11th, 2008, 01:17 AM   #10
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Don't care realy. He wanted info, he got it. I know my build isn't going to be no 800hp monster but I bet it's gonna be the baddest N/A 4v on this site.
That is being followed thru with right now.
Military Crew
U.S. Army Aviation
Old April 11th, 2008, 01:26 AM   #11
What all are you doing to your motor, Doc?
O o
\_\
Old April 11th, 2008, 01:29 AM   #12
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
There is thread on it in here. But its kinda under wraps how the motor will exactly be. It will hit the 500whp mark N/A though. And its not a 5.4 swap.
Military Crew
U.S. Army Aviation
Old April 11th, 2008, 01:43 AM   #13
99 Cobra
OneBoredGuy is on a distinguished road
500 whp N/A? You are going to love gas prices lol.
What are you looking to run in the quarter? I am wanting mid 12's lol not freaking 10's or quicker.
Old April 11th, 2008, 01:53 AM   #14
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Gas prices? LOL I don't care about that. I am not concerend with the 1/4 times I just want a nasty (the nastiest) N/A Mach 1 that will scare small children when I drive by.
Military Crew
U.S. Army Aviation
Old April 11th, 2008, 08:23 AM   #15
compgun's Avatar
1997 Mustang Cobra
Teksid.
Yes going twin tubo setup.Suspension is allready started and more planed. This is just a fun weekend car and not dedicated drag or auto x car. As for as cost, speed is a question of money I know this. But buy what I can, as I can and can do the work myself. Thank all of you for help and insight.
97 Cobra
Borla Cat-Back
Spec Stage 3 Clutch
Bullitt Rims
Lower springs
3.73 Gears
100 shot Nitrous
Old April 11th, 2008, 09:23 AM   #16
1996 Ford SVT Cobra
13.36@102
If it's any idea and if you don't want to do the work I spoke to a performance shop and was told for around $15,000 the car could be built to put out and handle around 700hp and most likely run 9's and street driven.
If that's high, I don't know, just throwing out a figure I was told. I figured it wasn't that bad considering the turbo, exhaust, transmission, tubular front end, roll cage, safety equipment, forged internals, etc.
Do I have that money? Nope! It's just something for me to think about later down the road when I'm looking for single digits, right now I'm happy 12-13.
I didn't mean for the first reply to maybe seem jumpy, just it seems like a regular occurence in the 96-98 board : "Hay, guys I'm going to supercharge my car once I'm out of school, I'm going to be a junior in high school next year. What do I need to do this?"
How is your car running with that 100 shot, E/T?
Old April 11th, 2008, 08:00 PM   #17
compgun's Avatar
1997 Mustang Cobra
Ryan Paymaster
[/QUOTE]I didn't mean for the first reply to maybe seem jumpy, just it seems like a regular occurence in the 96-98 board : "Hay, guys I'm going to supercharge my car once I'm out of school, I'm going to be a junior in high school next year. What do I need to do this?"[/QUOTE]
Yes I know what you mean, nothing to get upset about. $15,000 is a very good deal, but I have just as much fun wrenching on my car as I do running her and I can buy parts when I have play money. 100 shot is FUN just don't hit it in 1st or 2nd - wait until 3rd! 75 shot is alittle more street friendly.
97 Cobra
Borla Cat-Back
Spec Stage 3 Clutch
Bullitt Rims
Lower springs
3.73 Gears
100 shot Nitrous
Threads Similar to: cast or aluminum block
cast or aluminum tvc2389 5.0 Mustangs 2 March 13th, 2008 01:07 PM
How to polish cast aluminum rxnodoze02 Visual 4 February 4th, 2008 10:42 AM
4.6 aluminum block energiesource 99-04 6 August 3rd, 2007 11:25 PM
aluminum block acg 96-98 1 February 21st, 2007 10:38 PM
cast iron vs aluminum heads 86er 5.0 Mustangs 5 December 11th, 2006 08:46 PM
