11.21@123 -150 shot
![]() iTrader: 1 reviews
Moser 31 spline axles
I have built the rear of my Mach with Moser 31 splines, 31 spline trac lok, 4.10s, and FRPP girdle. I have run ET drags at the track twice. Is it possible to bend an axle with around 300 rwhp? I dyno'd my car last weekend and it had a definite wobble at low speeds on the passenger side. Can I effectively evaluate this by jacking up the car and turning the wheels to look for a wobble? Your thoughts?
You shouldn't have done any damage to a Moser 31 spline axle at that low of horsepower.
11.21@123 -150 shot
That is what I was thinking. I have been launching at 6000 - 6500 rpms but that was only the last time out. Could it be an axle bearing? Besides a tear down, anyway to diagnois the problem?
#5 | |
11.21@123 -150 shot
#7 | |
11.21@123 -150 shot
#9 | |
11.21@123 -150 shot
The general concensus is I didn't bend the axle. I will investigate this weekend and report back.
RLY SRS
I was asking what the tuner thought about your car doing that...
I would take the axle out and send it back...You should not be bending axles... |
#11 | |
11.21@123 -150 shot
a local guy with the 31 spline moser axles had the same problem. its a white saleen with all the bolt ons with slicks. he brnt 1 axle out near the hub
pull the wheel off, and see is the axle stub wobbles...bearings going to make a grinding noise, especially turning left and leak oil. sounds like a rim or tire problem.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
are your axle tubes welded? could have torqued one a little bit and it's causing excess wear on your bearings
Threads Similar to: Moser 31 spline axles
| Strange or Moser 31 spline axles? | 03 R Code | General Tech | 20 | September 5th, 2007 11:51 AM |
| 31 Spline Axles??? | Bies08 | V6 Mustangs | 25 | July 13th, 2007 11:35 PM |
| 28 Spline Axles | stangliter04 | General Tech | 3 | September 25th, 2006 10:28 AM |
