Shifter
Old April 13th, 2008, 05:58 PM   #1
pvoida's Avatar
2004 Mach 1
pvoida is on a distinguished road
Shifter
Is there an easy way to determine if you have a stock or after-market shifter. Which really boils down to what does the stock shifter on a 2004 Mach 1 look like?
Old April 13th, 2008, 06:00 PM   #2
DeMello is an unknown quantity at this point
my dad just told me my shifter is after market and i dont belive him so can sombody show me what the stock shifter in a 01 gt looks like to
sry to thread jack
Just Another Bolt on GT
[IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG]
Stock Longblock - 287/276
Low 12s NA! 10s on the spray?
Old April 13th, 2008, 06:00 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Does it feel like you have to grope the passenger when you shift to 5th? Or better yet is it hard to get into 3rd? If so then you have the stock shifter. If you have an aftermarket shifter it will have it's name on it. You can check by lifting up the boot and taking a look.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old April 13th, 2008, 06:02 PM   #4
pvoida's Avatar
2004 Mach 1
Thanks, I will do it.
Old April 13th, 2008, 06:03 PM   #5
yea mines a bcith to get into 3rd lol
Old April 13th, 2008, 06:04 PM   #6
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I used to miss 3rd quite a bit and it was frustrating. I haven't missed once since I put in the Tri-Ax.
Old April 13th, 2008, 06:06 PM   #7
pvoida's Avatar
2004 Mach 1
You know what's funny? I popped the boot and it says Tri-Ax on the shifter but it is still like stirring a garbage can full of pool balls with a toothpick.
Old April 13th, 2008, 06:08 PM   #8
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you may just have the handle and not the short throw shifter itself
Old April 13th, 2008, 06:09 PM   #9
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Or they took the stop bolts off.
Old April 13th, 2008, 06:11 PM   #10
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you shouldn't be using the stop bolts in a mach anyway it has internal shift stops
Old April 13th, 2008, 06:14 PM   #11
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
There's a difference between having them on and off though. I took mine off and then tried it with them on. I liked it much better with them on.
Old April 13th, 2008, 06:19 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
whatever floats your boat bro.
i'll have to tell ya though it's not recommended
and the instructions warn that you can do damage to your transmission.
just an fyi
Old April 13th, 2008, 06:25 PM   #13
armymike63b's Avatar
2004 mustang mach 1
armymike63b is on a distinguished road
Send a message via AIM to armymike63b Send a message via Yahoo to armymike63b
the pro 5.0 says to use them and it's awesome
Old April 13th, 2008, 06:27 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Tremec has also released this bulletin: Tremec Transmissions
Service Bulletin 03.01
Subject: Aftermarket Shifter Stops
Transmission Models Affected: ALL
Severe damage may be caused by installing an aftermarket shifter with "shift stops" on any TREMEC transmission. All TREMEC transmissions are designed and manufactured with built-in shift stops to prevent over shifting. Therefore; shift stops on aftermarket shifters are totally unnecessary when used on a TREMEC transmission. TREMEC "TR series" transmissions have multiple shift rails with shift stops on the gearing. TREMEC "T series" transmissions have a single shift rail system with stops built into the guide plate.
When installing an aftermarket shifter on a TREMEC transmission it is best to remove the shift stops to avoid miss adjustment, and the potential of the screws vibrating lose. A misadjusted shift stop can cause an under-shift, which may lead to a gear jump-out situation. If the transmission jumps out of gear, the shift fork can be bent causing permanent damage to the transmission. Shift forks can also be damaged by "clash shifting". A clash is caused by a missed shift.
Neither an "under-shift", nor a "clash shift" can be prevented by shift stops. TREMEC shift forks are designed to take loads up to 1,000 lbs. However, a gear jump-out may well exceed 1,000 lbs. of force, which may result in a permanently damaged transmission.
Old April 13th, 2008, 06:32 PM   #15
pvoida's Avatar
2004 Mach 1
I sure have a gear grinder here, reverse is tough and so is short-shifting to 3rd or fifth
Old April 13th, 2008, 06:32 PM   #16
2004 mustang mach 1
yeah but wont taking the stops out make u have to shift far
Old April 13th, 2008, 06:32 PM   #17
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I'll have to do some adjustments then. I've had 4th jump out a few times when I've ran hard.
Old April 13th, 2008, 06:33 PM   #18
pvoida's Avatar
2004 Mach 1
So, I have to remove the rubber boot to see if there are stop-bolts?
Old April 13th, 2008, 06:34 PM   #19
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
see?
not at all.
that's what the short throw is for.
I recommend an MGW
Old April 13th, 2008, 06:34 PM   #20
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
The steeda says "Tri-ax" on the base of the shifter, what's on the handle is irrelevant.
and if you have a T45, you NEED the shift stops, or you can overshift (been there, did that, luckily had most of it covered by warranty).
O o
/¯/______________________
\_\
Threads Similar to: Shifter
MGW shifter KIKa55GT 96-98 20 January 16th, 2008 01:18 PM
Pro 5.0 Shifter Fast98stang 96-98 4 December 21st, 2007 09:29 PM
Shifter Dawgfude03GT 99-04 28 September 27th, 2007 12:22 AM
MGW Shifter DrHolliday 99-04 17 March 24th, 2007 11:32 PM
