2003 Ford Mach
Traveling at the speed of a photon
Tokico?
Just need your opinion if these are a suitable application for an all street machine.
Total Tokico Front & Rear Strut/Shock Package - For 94-04 Mustangs - StangSuspension.com
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I think tokico's are good shocks/struts but as you already know im a fan of KYB's.
2003 SVT Cobra
11.70 @ 121
yeah but not those.
Honeybadger is Crazy
I prefer Bilsteins. I run them on all of my vehicles. They cost more, but they're worth the money.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
97TT Gobra
dyno queen
i had toks on my whip...had to remove them for the stranges...They worked great for a mild set up going down the road and playing...wouldnt dead hook for squack...the stranges are 9 way adjustable and work much better for all needs in my opinion...
97TT Gobra For Sale 697rwhp 662rwtq no one to play with but the dyno |
2003 Ford Mach
I just switched over to a new wheel setup and i have nitto 555's all around; so i was wondering if these would help the tires grasp the pavement and/or last longer than our stock units. Bilsteins would be great, but i dont see myself spending that much for a set. I can improvise with another descent product.
same here
2003 Ford Mach
Damn you...lol So, am i slowly being pushed into purchasing these>?
Priest of the Car Gods
I run bilsteins too; one of the best things I've done to the car so far.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
I can't say enough about how happy I am with my Strange Engineering 9-way adjustables. Rides like stock, helps hook like hell.
if you put "cheap" adjustable shocks (i.e. < $1000 set) on a shock dyno, they suck tremendous amounts of ass compared to a comparably priced non-adjustable shock. The valving is horribly inconsistent between settings.
Also, you shouldn't be using shocks to make up for too-soft springs. Shocks should be matched to your springs. Using shocks to effectively up your spring rate will only result in blowing out your shocks long before their time.
97TT Gobra
dyno queen
go strange,,they work wonders for whatever the adventure
#14 | |
$1000 is a ton of cash for most people to drop in shocks alone. I picked up Strange shocks and struts, Steeda Drag Springs, new bushings, etc. all for under $1000 or so. |
I paid $650 for my bilsteins, but they were also a shock that was well suited for my springs. Drag shocks, and lowering springs, doesn't that make that car ride like a tank?
2003 Ford Mach
The thing is I don't plan on lowering my car. I'm satisfied with the machs stance/height. Ahhhh forget it. I'll save up and purchase the Bilstein set from american muscle.
Typically how long does a Bilstein setup last? Keep in mind i'll never switch the springs.
How much do you drive your car? i thinkit depends on driving tactics, usage, and so forth...
I have 8k mi on my car. I barely drive it, so they'll last a while for me.
They should last a long time if matched properly to your springs, and they have a lifetime warranty IIRC, so I believe that you can get them rebuilt/revalved for free. (definitely double check that though).
And yes, $1k is a LOT of money for shocks, which is why I suggest non-adjustables: you can get the same quality of shock for less than half the price. To get the same shock quality as you get in a Bilstein in an adjustable shock, you'll be paying around $500 per CORNER. And just because you're drag racing doesn't mean you don't need good shocks, you're still dampening the excessive movement of your springs.
2003 Ford Mach
My car only sees daylight on the weekends.
#20 | |
2003 Ford Mach
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] Last edited by chris1; April 16th, 2008 at 12:57 PM. |
Threads Similar to: Tokico?
| Tokico HP struts/shocks | mustang fanatic | 2005 - 2010 | 20 | March 24th, 2008 06:02 PM |
| Tokico D-Spec | Jucostud | 2005 - 2010 | 17 | January 5th, 2008 12:05 AM |
| tokico and lowering | patwrecked | General Tech | 5 | June 13th, 2007 05:15 AM |
| Tokico Shocks And Struts | sonicblue | 99-04 | 3 | November 21st, 2006 01:08 AM |
