Does any1's shaker rattle and lean - Page 2
Old April 15th, 2008, 12:03 AM   #21
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
My shaker got raised when I put my intake spacer on.
+1 If you raise it and then put the spacer in you are gonna hit the hood. Just an FYI
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old April 16th, 2008, 03:04 PM   #22
Honeybadger is Crazy
futureMACH1racer's Avatar
2008 F-250 Super Duty
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Doc, you know too much.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old April 16th, 2008, 04:38 PM   #23
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Take the shaker off (2 bolts, one on each side, I think are 10mm or close to that) and use a ruler to be sure all of the bolts that is sits on are even from front to back and right to left. If the guy before you took it off he may have loosened some of the bolts more than others for some strange reason. Like someone said earlier look for those rubber grommets on the underside of it, if one of those is missing that will most likely be the reason it's rattling. If you want it to sit higher just back the "stand" bolts out a few turns and use some lock tight to be sure they don't walk or rattle out all the way.
P.S. don't buy the shaker spacer kit. They look like trash, the corners on the spacer are squared and our shakers are rounded on the edges...
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old April 16th, 2008, 06:11 PM   #24
If you want to raise the shaker get one of these instead....
PHP Intake Spacer w/Gasket
They raise the shaker, and they help you gain more power.
Old April 16th, 2008, 06:26 PM   #25
WILD Jeff's Avatar
2005 Mustang GT
WILD Jeff is on a distinguished road
Send a message via AIM to WILD Jeff
Just use your common sense and play with it until you find the source.
- WILD Jeff Shrewsberry
Old April 16th, 2008, 06:28 PM   #26
MM's Ford Truck Guy
FX4DTUF's Avatar
99 ranger,2010 ranger
does nice burnouts
FX4DTUF has a spectacular aura aboutFX4DTUF has a spectacular aura about
ight will do man thanx for all the advice guys
1999 xlt 2.5 ranger lowered 5/6 on 17in bullits
2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits
Threads Similar to: Does any1's shaker rattle and lean
lean really lean plaese help 331 stroker stangzilla 331 94-95 8 January 30th, 2010 07:58 PM
lean patwrecked 5.0 Mustangs 4 September 10th, 2007 10:59 PM
Need help with lean A/F ! mow 2005 - 2010 6 April 28th, 2007 02:58 AM
Lean! Clayhistorian V6 Mustangs 5 April 24th, 2007 12:07 PM
My Car Is Running Too Lean, How Do I Fix It? SPEEDRACERCHICK02'92' 99-04 10 December 14th, 2006 12:54 AM
