Discussing 03 Cobra Recommended Slick Size in the 4V / SVT Forum. What size rim would fit on my 03 cobra. It has irs and stock back ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
My lug nut has more torque than your Honda! |
1994&2002 mustang gt
will 15's clear the breaks? i know they wont in the front i think 17 is the min up front...
sorry i know nothing about tire size... are you lowered? if so how much? |
I am just looking for in the back. I am not going to be doing anything with the front tires. It is my daily driver so it would just be something to put on there when I race it. It is lowered on eibach springs. I am not sure how much but probably like 1.5 or so.
2003 Mach 1
Yea it will clear.
Under Construction Project N/A 4V Under Way Rep is always welcome |
ok so the 15s will clear without modding it. what size backspacing should i get? or what will look/work best? and would the 15x8s work on the 10 inch tire?
11.95@113MPH
You have to do some grinding on the rear to get 15's to fit....if you're stil IRS of course.
2002 Mustang GT 4.10's, NX 100 shot, MGW shifter, ET Streets 60ft: 1.63 1/8 ET: 7.60@90MPH 1/4 ET: 11.95@113MPH 1986 Mustang GT 4.10's, NX 150 shot, TKO, "P" heads, etc... 1.93 60ft 8.33@84MPH (stock w/100 shot) |
#7 | |
2003 Mach 1
Not with the right back spacing you don't
what size backspacing would i need?
can anyone help me with the backspacing???
11.95@113MPH
15x10 6.5in BS Weld ProStar needs grindin
well what will without grinding.
03 cobra
10.48@130.56
If you have stock cobra brakes any 15" rear wheel will require grinding. The wider you go, the more grinding it'll require. I ran 15x10's and had to grind the banjo bolt, tie rod end and the spindle where the tie rod mounts. There are several wheels made to clear the brakes. Bogart makes a 16x10 and diamond racing makes some more budget minded 16's to clear.
![]() Qwickest/Fastest no nitrous eaton in the country. 10.48@130.56 |
do you know where to get some like 26 or 28 x 10.5 x 16 slicks. i would most likely wan some dot approved slicks to run but if i can't find some then straight slicks would work too. i got some rims that i can put them on i just need to find somewhere that sells the tires.
#14 | |
03 cobra
10.48@130.56
wheels 8-15-5.5 back spacing......slicks 27-11.50-15s
so the 11.5 inch tires would fit on the 8 inch rims? just making sure so i dont mess up on them and have to wait longer. and thanks for all the help.
2004 Mach 1
Too Slow
I wouldn't go any wider than 10" unless you have some serious power. To much traction can be a bad thing. Also, watch out for wheel well clearance. 10" wide wheels with a +22mm offset, and 295, or 11" rears with hit the quaters if the car squats hard. My car trnafers really well and slams the ass end down, I had to roll my quarters because I caught while launching.
![]() MM MACH 1 CREW MEMBER #2 REP IS APPRECIATED 2008 Yamaha FX Nitro RTX for sale 0 miles still in plastic $11,000 firm |
well i am hoping to be right around 500 to the wheels. i will probably just end up going with the 10.5 slicks or maybe even 11.
Threads Similar to: 03 Cobra Recommended Slick Size
| Slick Valve Covers | djphatnutzinc | 99-04 | 10 | December 21st, 2007 03:48 AM |
| One Slick Mustang! | jspagna1 | Classic Mustangs | 12 | December 19th, 2007 11:06 PM |
| What size slick on 15'' turbine wheel??? | black88 | 5.0 Mustangs | 1 | October 19th, 2007 09:26 AM |
| What'z the best exhaust system recommended for the 03' Cobra | WilltheThrill | Modular Mustangs | 2 | January 5th, 2007 10:51 AM |
| Slick Mustang Wallpaper | mdvaldosta | The Clubhouse | 7 | June 3rd, 2006 06:46 PM |
