#21 |
Well, its simple really. The Cobra driveshaft is shorter than the GTs because the Cobra uses a T56, which is longer than the T45 used in the GTs. The Cobra driveshaft wont work in the GT if you use the T45, because it will be too short. If you keep the solid axle in the GT, and want to use the T56 out of the Cobra, the driveshaft should work. Plus or minus some modifications to make it fit properly.
Putting a solid axle in a Cobra requires some modification to the driveshaft to make it all fit properly.
#22 |
Perfectly worded Goblin! I'm drunk right now and totally understand...haha. I will be using the T56 so I guess that means I'll use my Cobra DS and then the GT rear end. Now that the Mech. side is pretty good.
Now to the fuel... All I need are the injectors and fuel pumps?? (And thanks everyone for the help thus far...lots of good knowledge on this thread!)
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
#23 |
Genibus Nitito Canus
u will need the tank too if I remember correctly
#24 |
You'll need the entire fuel system and its wiring from the Cobra. Yes, that includes the fuel tank.
Threads Similar to: 03 swap ??'s
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 09:00 AM |
| 2.3 swap | djh1286 | 2.3 Mustangs | 1 | March 4th, 2008 02:49 PM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
