Discussing What horsepower and times should i see? in the 4V / SVT Forum. can anyone give me an idea of what i should see for horsepower and 1/...
Old April 24th, 2008, 08:59 PM   #1
can anyone give me an idea of what i should see for horsepower and 1/4 mile times? here is my set up.
2.93 upper
6lb lower (about 18 psi)
c&l intake
k&n filter
twin 65mm bbk throttle body
heat exchanger
sct big air 2400 mafs
magnaflow x pipe no cats
borla stinger catback (all piping is 2.5)
tuned on diablo predator. air/fuel ratio is about 11 at wot
wideband
aluminum driveshaft
short shifter (not like it adds power)
lightened flywheel
exedy stage 3 clutch
there may be a couple other little things. i bought the car at a dealership and most of the stuff was done to it already. the car pulls hard and i have raced a couple people on the streets that were 11 second cars and i seen them run so i know thats what they ran. i pulled on them not alot but from a second gear roll to about 120 or so i was about 2 to 3 cars ahead. i am planning on running it with slicks in the next couple weekends but i am waiting for it to get out of the shop. my stepdad took it out without asking and wrecked it 5 minutes into driving it. and sadly the car has been in the body shop for almost twice as long as i was even able to drive the car (4 months). any input would be great. thanks for your time.
My lug nut has more torque than your Honda!
Old April 24th, 2008, 10:52 PM   #2
S197 Moderator
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
I am assuming this is a Terminator. Have any suspension mods been done?
Bassani Crew Member #1
Sign up at Modded Autos
Originally Posted by 97Cobra View Post
if you dont want the mods coming at you dont do somthing to deserve it.
Old April 25th, 2008, 01:43 AM   #3
ya its on 03. and it has springs, strut tower brace, and sub frame connectors. that is all that i know of. i don't know if they were aftermarket sway bars or if they were stock. i just glanced at them.
Old April 25th, 2008, 02:40 AM   #4
NXstang's Avatar
11.95@113MPH
is it still IRS? please god I hope it isnt ruined with GT crap.
Im unsure but slap it on the track and let it eat. the thing that kills IRS's is Wheelhop. If it doesnt have one, get an IRS brace. And run a Bias Ply (et streets, et drags, etc).
good luck,
2002 Mustang GT 4.10's, NX 100 shot, MGW shifter, ET Streets
60ft: 1.63
1/8 ET: 7.60@90MPH
1/4 ET: 11.95@113MPH
1986 Mustang GT 4.10's, NX 150 shot, TKO, "P" heads, etc...
1.93 60ft 8.33@84MPH (stock w/100 shot)
Old April 25th, 2008, 11:23 AM   #5
it does still have the irs. no irs brace. also what is a Bias Ply? never heard of that before. and it doesn't really get wheel hop. surprisingly i have never got wheel hop with. they usually get spinning too much to get wheel hop.
Old April 25th, 2008, 11:25 AM   #6
I Touch Myself Sometimes
HMUSN's Avatar
1991 GT
19.83 @ 12mph
it's a design of tire.
MILITARY CREW
FOUNDER
Originally Posted by itschristorres8 View Post
only bang for the buck is Foxs
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old April 25th, 2008, 07:46 PM   #7
oh i am going to be running slicks. i posted a thread asking about slicks. if you can see it please help me out.
Old April 26th, 2008, 12:28 AM   #8
ZOOTOXIN's Avatar
2.93 upper
c&l intake
k&n filter
heat exchanger
wideband
aluminum driveshaft
lightened flywheel
you get 18psi with a 2.9 pulley kit? That is extreme. the 2.76 gives only 5-6 extra boost. Is it the eaton SC or did I miss something in the mods?
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Old April 26th, 2008, 01:16 AM   #9
NXstang's Avatar
11.95@113MPH
Bias Ply is the design of the tire....Slicks are a Bias ply. ET Streets, Quicktime Pros, ET Drags, etc are all a Bias ply designed tire. The sidewalls are soft and wrinkle on launch. Drag Radials are only truly effectiveo n an automatic car where it doesnt shock the drivetrain as much on a launch.
I dyno'd 338HP/475TQ ando n a 27x10.5 ET Street with BONE STOCK Ford OEM suspension, I cut a 1.63 60ft on many of my 11.9/12.0 passes.
Just find her sweet spot and let it eat. TONS of people have went into the 10's on factory 03/04 cobra IRS'. good luck.
60ft: 1.63
1/8 ET: 7.60@90MPH
Old April 26th, 2008, 02:48 AM   #10
it is the 2.9 upper with the 6lb lower. thats why it is at 18. sometimes it will hit 19 or so but most of the time it is just 18. it is also just the stock eaton. i am not sure if it has been ported or if it is just stock but it definatly screams. and NXstang that is some good times with such little mods. obviously the nx is a big part of it but that is still sweet. i am hoping that i can run under about 11.5 or so. well i am almost positive i will run under that i just don't like to over guess things. but i don't see why i wouldn't be atleast 500.
Old April 26th, 2008, 08:54 AM   #11
NXstang's Avatar
11.95@113MPH
Just powershift it and don't be scared to launch it. If it starts wheelhopping, get out of it IMMEDIATELY. Thats what kills IRS'.......
You car with those mods should be easy mid 11's. But remember, that Eaton is maxed out...you need to consider either a bigger blower or get that one ported so its more efficient.
And thanks for the ocmpliments!
60ft: 1.63
1/8 ET: 7.60@90MPH
Old April 26th, 2008, 05:40 PM   #12
2004 GT
slow....
you should have well over 500rwhp
2004 Crimson red GT
saleen s/c, bolt ons
Old April 26th, 2008, 11:48 PM   #13
well i am debating getting it ported to a stage 5 and getting 60lb injectors and a boost a pump or going all out and getting the big 3.4 whipple. but i am kind of thinking that that is going to be a little too much for driving it everyday. maybe just eventually doing it. thanks for all the input.
Old April 27th, 2008, 01:44 AM   #14
Avaric3's Avatar
1999 V6 Mustang
shootin for 13.2-13.3 w/ nitrous :)
whipple ftw
COMING THIS FALL TO A STREET NEAR YOU- Dynotune 75 wet shot, aluminum ds, VAP windstar upper, VAP intake spacer, MMR front coil-overs, Eibach sportline rear springs, xcal 3, 4.10s+T-lok, udp, lt headers, o/r h, mac catback, 275/50-15 555Rs
Old May 4th, 2008, 11:18 AM   #15
Originally Posted by Avaric3 View Post
whipple ftw
?? what is ftw?
Old May 4th, 2008, 11:25 AM   #16
just another mod.
weems's Avatar
2003 Mustang Mach 1
12.9@109.3
for the win
Beautiful
Old May 4th, 2008, 02:04 PM   #17
Editor
Smoothgrandmama's Avatar
he should have close 460 rwhp not 500
Old May 5th, 2008, 05:31 PM   #18
baine21225's Avatar
what are the pros and cons of kb vs. whipple?
Old May 5th, 2008, 06:34 PM   #19
Editor
whipple is more reliable. but there pretty much the same thing.
Old May 6th, 2008, 01:16 AM   #20
just wondering but where are you coming up with those numbers. i am not trying to say that in a rude way.
Threads Similar to: What horsepower and times should i see?
horsepower ? Racinjason81 SVO 1 February 13th, 2008 10:02 AM
how much horsepower kenevil331 5.0 Mustangs 4 August 2nd, 2007 11:38 AM
horsepower brad03svt Modular Mustangs 2 April 22nd, 2007 11:46 AM
horsepower Murderjetz V6 Mustangs 8 March 19th, 2007 11:10 PM
Can 1/8th mile times give est 1/4th times? Nightstick Drag 3 April 16th, 2006 10:20 PM
