Tranny swap update
LinkBack (1) Thread Tools
Old May 1st, 2008, 12:51 AM   1 links from elsewhere to this Post. Click to view. #1
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Tranny swap update
Just wanted to give you guys an update on the tranny swap and the build. The Long Tubes are just about done. Little FYI if you 4v guys do the headers I reccomend reusing the studs that are in the heads for the exhaust manifolds. My headers came with new bolts but its pretty hard to align the gasket, line up a bolt, line up the hole and try to get it tight at the same time. So I pulled it back out and put the studs back in. This allowed me to put the gaskets on the studs and it held the gasket in place, plus it was a hell of alot easier to just thread the nut on the stud then have to align a bolt.
If you are planning the manual swap a couple things to remember that I forgot was. Flywheel bolts (the flexplate bolts are too short),If you are not getting an aftermarket cable and quadrant you will have to make sure all the stock parts are on your new clutch pedal assembly for the cable. The key lock on the Automait is cable driven to the shifter, if you don't wanna change out the key lock in the column just tuck the cable up under the center (when you do it you will see what I mean),.
Now for the goodies. I went with a 1 piece forged flywheel from XTD, It weighs in at 12lbs and is SFI approved. It is for an 11" clutch but it has provisions for the alignment pins that will allow you to run a 10.5" clutch as well. It is a resurfaceable flywheel so when its time for a new clutch it can be surfaced and not have to get a new insert like the aluminum ones I was looking at. It ran me $210 shipped so it was a bargain and it is lighter than the other aluminum ones I was looking at.
Next is the Aluminum DS. Got it from AM and it is a very nice piece. I was suprised at how light they realy are compared to the stock one. Got the Spec stage 2 clutch. Prochamber is coming in tommorow and the only thing holding up stabbing the tranny is the starter index plate. This is the thing that is pissing me off. Promotion has it and its cheap but they are so swamped I can't get them to get it shipped out. I am going down to Ford tommorow and see if I can't track one down.
So when it rolls out next week my mod list will be as follows
P&P'd TB
C&L Mass Air Meter
C&L Inlet
P&P'd Upper and Lower manifold
PHP intake spacer
Mac Long Tube Headers
Mac Prochamber
Mac Pro Dumps
FRPP Aluminum DS
XTD Light weight flywheel
Spec Stage 2 clutch
Steeda Tri-Ax
3.90's
31 spline diff
31 spline Moser's
FRPP C-Springs
Stewart Components Water Pump
Steeda UDP's
Royal Purple in Motor,Trans,and Diff
Diablo tuner
Ford GT Supercar fuel pump
Zex wet shot 100-150 shot
I will be taking a bunch of pics of the parts and of the car so you can see where I am at. I will take some more as we start putting it all back together the next few days. I will keep you guys updated.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old May 1st, 2008, 08:45 AM   #2
ECUSVT31's Avatar
1999 SVT Cobra
13.43
ECUSVT31 is on a distinguished road
awesome cant wait to see
Old May 2nd, 2008, 01:28 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Here are some pics of the goodies I got and some progress pics.
Enjoy
Military Crew
U.S. Army Aviation
Old May 2nd, 2008, 01:33 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Military Crew
U.S. Army Aviation
Old May 2nd, 2008, 12:51 PM   #5
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
Nice.....looks to be coming along good
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old May 2nd, 2008, 01:01 PM   #6
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Did you say you got the index plate figured out??
Old May 2nd, 2008, 01:08 PM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Yea I got one thru Ford, heading to pick it up today.
Military Crew
U.S. Army Aviation
Old May 4th, 2008, 01:40 PM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
IT'S ALIVE!!!!!!!!!!!!!!
Just about done with this beast. It was a big project and it went off with out too many big problems. worked 12hrs last nite then started back on the Mach and we just fired her up a few minutes ago and it sounds freakin wiked! We took a video and I will get it up later tonite or tommorow. I am still going to do a full write up on this because there are some things that can bite you in the butt. After I get it on the road and going good I will start the write up on it so you guys can see what we went thru and it will help you speed up your swap. I will post some pics from this morning in a few so you can see how it came along.
Military Crew
U.S. Army Aviation
Old May 4th, 2008, 02:00 PM   #9
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
FRPP aluminum DS and Prochamber
Notice the bolt holes for the front of the shifter on the tranny are not showing? Had to trim the metal back where those metal clips are for clearance to allow for the shifter.
Thanks for the comments guys, I am as giddy as a school girl now that I heard her fire up again and everything is going good. Just a few things left and tommoro nite we are heading down the old twisty highway to break the SPEC in.
Military Crew
U.S. Army Aviation
Old May 4th, 2008, 03:10 PM   #10
TheUNZippee!'s Avatar
Mmm looks amazing, Doc.
You should be my cyber best friend!
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old May 4th, 2008, 03:11 PM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
you had me at MMMM zip you had me at mmmm
Military Crew
U.S. Army Aviation
Old May 4th, 2008, 03:12 PM   #12
~tee-hee~
I bet you can't wait to get out there and get on it.
Or to drive your car, either!
Old May 4th, 2008, 03:19 PM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
~tee-hee~
O yeeaaa. started it up this morning and about had an orgasm... well ok lets be honest I nutted twice. It sounds amazing. I hope to have the vid up tonite but if not then in the morning. I will have sweet2k video some of the first test runs in the morning.
Military Crew
U.S. Army Aviation
Old May 4th, 2008, 03:21 PM   #14
Cool. Can't wait to see/hear/gently finger it
Old May 5th, 2008, 07:51 AM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
short clip of the start up, battery went dead of course. will finish a few things up on the car and hopefully take it out for clutch break in.
Old May 5th, 2008, 10:12 AM   #16
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I can't get that video to show. It keeps flashing on my screen and it could be a potential seizure hazzard
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old May 5th, 2008, 01:00 PM   #17
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
hey man let us know how that spec clutch works out. i'm having to pull my transmission again because the spec stage 1 i bought is a piece of garbage and chatters horribly. also, is that a self adjusting quadrant for the clutch cable? i'm thinking about getting rid of the self adjuster that comes stock and getting an adjustable cable.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old May 5th, 2008, 01:20 PM   #18
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
Its going to feel like a totally different car when your done.
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old May 6th, 2008, 03:31 AM   #19
ECUSVT31's Avatar
1999 SVT Cobra
13.43
yea i agree
Old May 6th, 2008, 12:04 PM   #20
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
badass dude. get some more vids up
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/68878-tranny-swap-update.html
Tranny swap update This thread Refback May 1st, 2008 08:57 AM
Threads Similar to: Tranny swap update
Update On Pi Swap Damaso 96-98 7 February 15th, 2008 02:29 PM
tranny swap? Uncle Humjaba 5.0 Mustangs 12 January 19th, 2008 10:18 PM
Tranny Swap? Dipped95gt Modular Mustangs 3 December 21st, 2007 11:30 PM
Tranny swap popmyclutch V6 Mustangs 8 October 8th, 2007 01:00 AM
tranny swap 95blueGT 94-95 6 June 9th, 2007 12:52 AM
