98 cobra going to go turbo
LinkBack (1) Thread Tools
Old May 2nd, 2008, 09:24 PM   #1
98 cobra is on a distinguished road
Well guys Im new to the site, I have a98 cobra with 70k all stock, and I need some advice, heres my ? , Will a gt35r at 9-10 psi put 480+ at the rear tires , here are the specs
t3 4t style , compressor a/r is .70
exhaust a/r is 1.06
its oil and water cooled
its dbb
now for sec ? is can you use shorty headers and run a mid pipe to a single out let? for the turbo up front?
And the final ? is what size wastegate would you use on in
Thanks for the help , Tom
Old May 2nd, 2008, 09:31 PM   #2
Black02GT's Avatar
03 Mach 1--~--1 of 2513
8.8 1/8 mile time
Black02GT is on a distinguished road
Send a message via AIM to Black02GT Send a message via Yahoo to Black02GT
i dont know crap about your situation. but a turbo cobra sounds like an incredible idea!
and welcome to the site!
Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice.
SaleenWolf720: need horsepower?? no, you just need bald tires, then you'll really feel the power
Old May 3rd, 2008, 07:36 AM   #3
BizCutt's Avatar
97TT Gobra
dyno queen
BizCutt is on a distinguished road
exhaust a/r is 1.06
its dbb
That stock bottom end prolly wont like that for long with 70k on it....but then again ive seen em go forever when they shouldnt....
Good luck with all that exhaust tubing in the tight ace space you have t work with...the longer you have to run them to a single outlet the longer the lag will be...but it should get you there for what your looking to do....
you should be fine with a tial 38 wastegate....
good luck with the build
97TT Gobra For Sale 697rwhp 662rwtq
no one to play with but the dyno
Old May 4th, 2008, 11:00 PM   #4
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
The block is definitely strong enough, but were I to go turbo, I'd be looking at replacing the internals with forged units and bumping the compression down under 8.5:1.
Predetonation is bad, mmmmKay?
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old May 5th, 2008, 09:14 PM   #5
So is the turbo good for the power , also I just want it to last for the summer and then i want to get a mmr block this winter I just want a low 12sec car , also update I have got the turbo tial wastegate(38mm) hks bov , sct xcal , and a aem wideband , and a autometer boost gauge so I have 2k worth of parts and I found so ic piping , an a presion ic, thanks guys for the hel so If I go with 450 will it last?
Old May 5th, 2008, 09:25 PM   #6
Why would you get a new block when you already have one good for 1k hp in the car?
O o
\_\
Old May 5th, 2008, 10:02 PM   #7
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Pipe length has very little to do with boost response.
98 Cobra >
The GT35R will be plenty for your goal. I'd suggest getting in touch with a turbo system fabricator to work out your plumbing and head unit placement. A 38mm wastegate will eventually limit the power you can produce, so if you have plans for more than 500rwhp in the future, consider a 44mm wastegate now.
Old May 5th, 2008, 10:04 PM   #8
my block is the 98 , no its not good for 1k hp, bt ya I was talking witha few guys about the pluming
, also got my tubular kmember , an a-arms
Old May 5th, 2008, 10:07 PM   #9
Goblin's Avatar
88mm
The 98 block is actually good for more than 1000hp. With the proper machine work, the Teksid blocks have successfully supported 2000+hp. Your block is nearly bullet proof. It will get the job done, i promise.
Old May 5th, 2008, 10:32 PM   #10
The 98 block is fine, as Goblin said. You just need to upgrade the reciprocating assembly with forged peices.
Buying a shortblock you'll probably actually end up with a weaker block than you started with, it'll just be rated for more hp because of the internals.
O o
\_\
Old May 6th, 2008, 07:06 AM   #11
BizCutt's Avatar
97TT Gobra
dyno queen
98 Cobra >
38's limit you at 500? wow mine made 697 on pump gas... and does tubing not effect lag time??? if it s a straight quarter milecar with a 2 step id say ok...but a street car??? hmmmmm
Old May 6th, 2008, 12:52 PM   #12
This is my street car I want to leave engine stock for now bt I want to get 450 at the rear tires for the summer is it doable , also is the sct going to do what I need
thanks tom
Old May 6th, 2008, 12:59 PM   #13
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
thanks tom
Yes, but you will have to take it to a reputable tuner. And without forging your internals, your car is going to be a ticking time bomb.
Old May 6th, 2008, 04:20 PM   #14
so these cobra are not very good engine that sucks. I want to pull low 12s do able on stock internals
Old May 6th, 2008, 04:33 PM   #15
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
You don't need a turbo system or 450 rwhp to hit low 12's in a streetable Cobra.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old May 6th, 2008, 04:34 PM   #16
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
You don't need 450 hp to pull low 12's. So low 12's are easily done with an internally stock engine, bolt on's and good drag suspension. Maybe a little weight reduction, which you have already started with that tubular k member and a arms kit.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old May 6th, 2008, 06:31 PM   #17
so what does it take , alredy got alot of the turbo parts and I want to boost it
Old May 6th, 2008, 07:11 PM   #18
03 R Code's Avatar
Like I said, a good drag suspension, some weight reduction and bolt on's. Something close to 300rwhp and a lighter weight car will make it into the low 12's.
A good example, there is a bolt on only Mach on the registry that, with lots of weight reduction and a GREAT drag suspension, is running 11.1x's. His engine is internally completely stock and I think he is dyno'ed around or a little over 300rwhp. You don't want low 11's so your car doesn't need to be as extreme as his is in the weight reduction and suspension categories.
You could have a low 12 sec car and then save your money and to the turbo and engine build at the same time.
Old May 6th, 2008, 07:53 PM   #19
O o
\_\
Old May 7th, 2008, 12:36 AM   #20
like I said I love boost never had a boosted v8 before , bt I had a low 13 sec zx2 I built and a stage 3 srt 4 that was a quick car bt I want a cobra so I got one bt it needs more power , so I f I boost can it hit 11s on stock irs with some slicks , also what gears would you get for boost
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/69175-98-cobra-going-go-turbo.html
98 cobra going to go turbo - Page 2 This thread Refback May 8th, 2008 01:13 AM
Threads Similar to: 98 cobra going to go turbo
PIC'S OF MY 93 COBRA 88MM TURBO 2BFEARD General Tech 87 August 1st, 2008 11:04 AM
Custom twin 57mm turbo cobra Blown04GT 4V / SVT 72 January 31st, 2008 12:08 AM
98 COBRA . . . Twin Turbo ? ? ? COBRA5 96-98 8 July 31st, 2007 09:57 PM
Turbo Cobra MnrlGry01gt Videos 5 June 24th, 2007 06:21 PM
