Discussing 2 completly different ?'s in the 4V / SVT Forum. First my fan on my 03 cobra has gone out does anybody know of a ...
Old May 7th, 2008, 05:19 PM   #1
2003 Mustang Cobra
First my fan on my 03 cobra has gone out does anybody know of a better fan to put on or if there is a need to put a different fan on other than stock.
next can i fit 10.5in rims on the front and still turn.
i looked for them in the searches but couldn't find anything.
thanks guys
Old May 10th, 2008, 09:46 PM   #2
Mustang RacR94's Avatar
03 mach 1
13.2@109
I'm not positive but 10.5 inch rims seem a little to wide for the front. My friend has 315s on his ls1 ws6 and it turns fine. As far as the fan it couldn't hurt to upgrade it. Check places like jegs.com. Lethalperformance.com and lmperformance.com. If anything this will bump the thread back up. But I don't see there being a reason to have to upgrade your fan at this point. Are you sure its the fan and not possibly a fuse. Not to try to say your wrong. Hope I helped
2003 Mach 1, 5 speed
MM MACH 1 CREW
---On the way---
Spec stage 2+
spec aluminum flywheel
Steeda adjustable clutch cable
steeda quick release quadrant
Old May 11th, 2008, 01:30 AM   #3
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.49@102
Yeah, seriously check anything electrical related to the fan. A 2003 Cobra fan shouldn't be dead in 2008. If you do a few minutes of braindead research you'll find a replacement fast.
Don't run a 10.5 inch wheel in the front. Obviously for drag racing the smaller the better, but the biggest I'd push the front is 9" which will clear more than fine. If you're worried about running a staggered setup in that case then you probably shouldn't be running a 10.5" rear/9" front at all Adding a 10.5" in the front is not only more weight but will cost you more money to throw new tires on those wheels. The whole point of a 10.5" rear is to A. look nice and fill that wheel wheel and the most important B. to add more tread to the ground which means more traction. Those front wheels aren't doing you much unless you're doing a crazy Focus SVT swap into your Cobra somehow.
If you're looking for a cheap staggered setup for your 2003 Cobra you could simply go to eBay. There's a few vendors there that offer a 9"/10.5" wheel setup at really reasonable prices. This is assuming you really like Cobra R / Bullet / FR500 wheels.
Good luck and I wouldn't recommend a 10.5" in the front. Right now off the top of my head I can't think of any benefits to this setup.
Old May 11th, 2008, 06:09 PM   #4
2003 Mustang Cobra
umm the fan somehow chipped a blade whether from a rock or who knows what. thanks for info on the wheels
Old May 12th, 2008, 09:33 AM   #5
C MY 4D's Avatar
2003 Cobra
11.98@119
There is a guy running 10.5s all the way around at VIR (road race track). I haven't talked to him to see what he has done to make it run that wide of a rim but I guess it can be done.
Black Cobra Club Member
Originally Posted by 8t6gt
Im more queer than a football bat I know this dude
Oh and BTW my emotional problems dont leave this IM :-D
Threads Similar to: 2 completly different ?'s
Blocked off my IAC completly tlgrant 99-04 21 February 7th, 2007 12:20 AM
