Discussing terminator swap in fox in the 4V / SVT Forum. im doing a terminator swap in my fox does anyone know how can i make ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
terminator swap in fox |
2004 Mach 1
Too Slow
Cut down your motor mounts. In the Novemeber '07 issue of MM&FF they tackle that issue. Also I think that they mentioned a compny that made a custom K member for this application. Goodluck, it's gonna be BMF when finished.
![]() MM MACH 1 CREW MEMBER #2 REP IS APPRECIATED 2008 Yamaha FX Nitro RTX for sale 0 miles still in plastic $11,000 firm |
i have seen a k member just for this swap.
check out like bmr |
terminator swap
my tublar k member thats in my cobra now should bolt in my fox correct
2004 Mach 1
Too Slow
IDK, if it would.
2003 Cobra
There's a guy I know on the local forum I frequent that is doing the same swap into a notch. From what he's saying it's alot of work, It should be an 8 second car when he's finished though. Good luck with the project though.
i know that AJE makes all their kmembers to order, i'd call them and see if they can fab you one up, then call kooks and have them do up some nice headers
1998 SVT Cobra
I remember reading about a full Terminator swap into an '84 Collector Edition (one of the cars with the Shelby stripes/GT-350 badging). IIRC, the only exterior mods were the '03 Cobra wheels, so it must be possible to fit the motor under the stock hood.
---------------------------------------------------------- The Sacred Chao says "MU" '96 Bronco XLT '98 Cobra '89 Camry AllTrac |
2004 Mach 1
Too Slow
MM&FF put one in a notchback, it has been done numerous times already. I'm anxious to see the pics of this buildup. It's been a dream of mine to build a '93 Cobra clone, and swap in a KB'd or Whipple'd termie w/ 6 spd, and IRS.
sounds like a lot of $$$$$
#11 | |
Editor
Secret In The Works
93 > You'll need atleast a 2.5" cowl hood, or a k-member, with drop mounts if you want to use the stock hood. Good luck with your swap, you'll need it. I didnt have any with mine!
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
I researched this same thing for about a month. Be ready for ALOT of work and extra $$$ to put into it. You're talking ATLEAST a 10 year difference in technology so almost nothing will be able to swap over on that end. I am not trying to insult you're inteligence by any means, but make sure you go through EVERYTHING before going ahead with this....PITA. (And as a side note...if you need a Termi engine I have one putting out over 450 HP for sale)
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
#13 | |
terminator swap
attempted to bolt up 2003 cobra k member it all lines up but i got to cut out the sway bar mount the 1 on the driver side hit the alt... keep u guys posted pics comming soon
terminator swap
does anyone know of a trany cross member for this swap
2004 Mach 1
Too Slow
I'm guessing that you'll have to fab that up.
Threads Similar to: terminator swap in fox
| big block fox swap | s1089 | Engine | 2 | February 11th, 2008 11:34 AM |
| Damn This Is Sweet Check It Out (Fox Terminator) | 8t6gt | The Clubhouse | 19 | November 26th, 2007 09:53 PM |
| Fox body Boss Swap | coyster | 5.0 Mustangs | 1 | May 13th, 2007 04:58 PM |
| 96 sohc swap to 04 terminator motor | 1quick96 | Modular Mustangs | 3 | March 20th, 2007 05:49 PM |
| 351W swap into a Fox body | Zeek | 5.0 Mustangs | 12 | November 4th, 2006 11:11 PM |
