Discussing Stalling Out in the 4V / SVT Forum. I just picked up my 04 Mach 1 and it has a tendancy to stall ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2004 Mach 1
13.46 @ 107
Stalling OutIt's only got 15K on the clock and mods are some stupid chip and gears. Would the tune cause it to do this??
![]() EAGLE SCOUTS OR GTFO |
03 mach 1
13.2@109
the tune or chip could be messing with it when your Rpms drop when the clutch is put in. I would suggest getting rid of the crude chip or tune either way besides that make sure the clutch isn't having problems engaging and disengaging Mach 1s don't usalky have problems so early just buy a sct chip or tuner and get rid of the beat chip. That's all I cab really say.
03 mach 1
13.2@109
You can try taking a trip to auto zone and having of plugged it up and seeing if its throwing codes it probally won't have any but its worth a shot
my 03 cobra did that exact thing and we basically adjusted the tune and more importantly raised its idle. These adjustments had to me made when the accu fab 65mm throttle bottle was added. Your throttle bottle and or plenum may not be stock and need adjustment. If you break fast and the idle drops really fast it shuts off everytime. It sucks but is an easy fix. be careful till its takin care off.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
2004 Mach 1
13.46 @ 107
Well, I had the mufflers cut off and dumps put on and it hasn't done it since. I'm guessing it had to do something with the exhaust. I am getting the tune removed IMMEDIATLEY. Any local HR guys know of any shops that will do it?? I went to Kimnach to have the PCM reset and it didnt do anything. Would DTP be able to help me out??
just another mod.
2003 Mustang Mach 1
12.9@109.3
get you a diablo or sct.
![]() Beautiful |
#7 | |
1996 Ford SVT Cobra
13.36@102
My 96 used to stall out too when I first bought it. She would stall out at a stop light once in a while but it went away after a couple days. Then a few weeks later at the track (it was a short shutdown area) I had to smash the brakes and the clutch and the car stalled. It's never done it since.
Besides the mentioned answers above of lose that tune I would say don't worry about it. It probably won't happen again.
unstoppable @ speed of light
That's a known problem with Mach's. It's addressed on the registry too. It's got to do with the MAF not letting in or reading enough air after the clutch is pushed in, I can't remember the exact explanation but it's somethig like that. It can be fixed through the computer with the some tuning.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
2004 Mach 1
13.46 @ 107
I'm going to use my sniper tuner on this one since I already got it.
if it has a chip you have to remove it before you can flash the computer , thats why they couldnt flash it, the chip overrides anything in the computer , take the pcm out and remove the chip , then make sure the computer still has the original tune in it once you hook your Sniper interface to it ....
Threads Similar to: Stalling Out
| Still stalling | ryanhewett466 | 5.0 Mustangs | 2 | April 18th, 2008 11:48 PM |
| Stalling Around | 95StangMX | 94-95 | 2 | October 19th, 2007 12:39 PM |
| Stalling! | flattusmaximus78 | V6 Mustangs | 28 | July 28th, 2007 12:12 AM |
| Stalling | RayvenHawk | General Tech | 1 | June 12th, 2007 12:43 PM |
| Why Am I Stalling | 99modular | 99-04 | 9 | September 13th, 2006 04:37 AM |
