Discussing Terminator Swap in the 4V / SVT Forum. Just recently locked up the motor in my 01 Cobra... i figured if im putting ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
01 Cobra
Terminator Swap
2003 Mach 1
Are you planning on doing it with the eaton on the cobra motor or just the short block and tranny?
Under Construction Project N/A 4V Under Way Rep is always welcome |
01 Cobra
im wanting to find a complete 03 Cobra motor and tranny ( which ive found a few) and directly replace it with my motor and tranny... then part out my motor and tranny...
2003 Mach 1
Depends on the price for the motor/blower setup. Remember you need the tank,fuel pump,heat exchanger,etc. if you wanna do the termi swap. But if you are gonna do a blower motor and just keep your tranny you could get it done cheaper and easier than a termi/t-56 swap.
just another mod.
2003 Mustang Mach 1
12.9@109.3
why would you need the tank?
![]() Beautiful |
2003 Cobra
The fuel tank in the Cobra has 2 fuel pumps, but I'm sure there's a way around that.
#7 | |
2003 Mach 1
The cobra tank is a baffeled tank and you definatly want that in a supercharged drag car with a returnless fuel system. Unless you plan to baffle your current tank.
1999 Ford Mustang
the world may never know
id just build the engine and trans you already have and put a blower or turbo on that. simplifies everything a lil bit
COMING SOON- FRPP Aluminum Drivshaft, VAP Windstar Upper Kit, VAP 1/2" Intake Spacer, MMR Front Coil-Overs, Eibach Sportline Rear Springs
01 Cobra
it just seems like it would be easier just to get a termi motor and swap it out...it has forged internals and the right compression and everything... and i dont think my T-45 will hold up well...then to make some money back I can just part out my other stuff
#10 | |
2003 Mach 1
If you get the ecu, cross member, drive shaft,etc from the termi it won't be too bad but again it all depends on how much the motor and trans and the extras runs you.
2004 Mach 1
I priced this out both ways with my car, and it's cheaper to build what you have, than to swap on for termie. You could build your motor into alot badder of an engine for the money that it would cost you just to do the swap, and full boltons.
![]() MM MACH 1 CREW MEMBER #2 REP IS APPRECIATED |
Threads Similar to: Terminator Swap
| terminator swap in fox | 93dohc s/c | 4V / SVT | 15 | May 16th, 2008 06:09 PM |
| Terminator | FlatlineMustangs.com | Pictures | 19 | February 15th, 2008 07:57 PM |
| terminator | criptez | V6 Mustangs | 22 | July 24th, 2007 03:44 AM |
| 96 sohc swap to 04 terminator motor | 1quick96 | Modular Mustangs | 3 | March 20th, 2007 05:49 PM |
| Terminator | Mustang RacR94 | V6 Mustangs | 28 | February 2nd, 2007 06:22 PM |
