water pump
Old May 21st, 2008, 05:37 PM   #1
1999 cobra
99blkcobra is on a distinguished road
Send a message via Yahoo to 99blkcobra
water pump
where do i get a stewert water pump? and i am looking for some mac long headers, do the hts work?
1999 Mustang Cobra (rebuilding, someday...)
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 01:28 AM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
EMP/Stewart Components STE50046L - EMP Stewart Ford Mustang 4.6L High Performance Water Pumps - summitracing.com
This is for pre 2001. There is another water pump that must be bought if your far is 02-04. If you have a car that is from 2001 you need to see what kind you need because some take one and some take the other pump.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old May 22nd, 2008, 01:40 AM   #3
1999 cobra
i have a 99, so that would work
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 01:43 AM   #4
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Just curious since this is a water pump thread and not to steal your thread 99blkcobra, but how reliable are CSR water pumps?
CSR Performance Products | Water Pumps | Simply the Best
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old May 22nd, 2008, 01:51 AM   #5
1999 cobra
never heard of them, but if some one has used them they would of brought them in just like the stewert water pump
is summit a good place to shop, i thought someone said something about them taking too long to deliver?
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 03:13 AM   #6
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
CSR pumps are very good pumps. Right up there with Meizere. The stewar pump is a mechanical pump though, not an electric. And the easiest thing to remember about which pump you need, the early 01 and later are long nose (hince the L at the end of the stewart part number) and the mid 01 and later have a short nose and there will be a S at the end of the part number for them.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old May 22nd, 2008, 09:12 AM   #7
1999 cobra
so summit is good??
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 09:39 AM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Originally Posted by 99blkcobra View Post
so summit is good??
yep thats where I got mine. you will need some shorther bolts for the pulley to bolt to the pump. Or some washers.
Military Crew
U.S. Army Aviation
Old May 22nd, 2008, 10:22 AM   #9
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
He may not. I don't remember how well the pump hooked up to Sweet's car, but 99 will be using a different pump than the Mach did.
Old May 22nd, 2008, 10:26 AM   #10
1999 cobra
wouldnt it be the one he posted at the top. its got the l at the end, long
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 10:36 AM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Yea I can't be sure if sweet's hit or not. Just letting 99 know ahead of time to be prepared for it just in case. I will ask him tonite at work and post up what if anything he had to do with his. But yes you need the one up top with the L at the end.
Military Crew
U.S. Army Aviation
Old May 22nd, 2008, 10:45 AM   #12
1988 Mustang GT
N/A
Thanks Doc!
Old May 22nd, 2008, 10:49 AM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Originally Posted by Modified88Dreamer View Post
Thanks Doc!
No Problem
Military Crew
U.S. Army Aviation
Old May 22nd, 2008, 11:11 AM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
No Problem!
Old May 22nd, 2008, 12:54 PM   #15
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
The link up top is correct for you. We were discussing whether or not you would need washers, which we don't know for sure. But washers are so cheap even if you don't already have a few dozen.
Old May 22nd, 2008, 02:54 PM   #16
1999 cobra
i dont have any, i work at autozone,
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 22nd, 2008, 10:13 PM   #17
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Originally Posted by HMUSN View Post
No Problem!
Military Crew
U.S. Army Aviation
Old May 25th, 2008, 09:26 PM   #18
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
+1 I also have the Stewart Pump, it's a much better quality item. The water pump with UDP's should be a nice gain, that you'll feel.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old May 26th, 2008, 10:42 PM   #19
1999 cobra
yea i just got to get the jlt intake, im going to install the springs, jlt, and water pump at the same time. so i wont regret anything
1996 civic dd
[/SIZE]
MM Cobra Club #3
Old May 27th, 2008, 06:34 AM   #20
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
jlt Ftl!!!
c&l Ftmfw!!!!
LOL
Military Crew
U.S. Army Aviation
Threads Similar to: water pump
Water Pump rainier446 99-04 14 April 17th, 2008 10:13 AM
pt 2. water pump Rustbelt 5.0 Mustangs 2 February 3rd, 2008 12:18 PM
Water Pump Badasstang281 99-04 2 December 27th, 2007 05:40 PM
Water pump ??? Fastback GT Classic Mustangs 15 February 24th, 2007 02:37 PM
Water Pump cobralini V6 Mustangs 1 August 3rd, 2006 06:48 PM
