1999 cobra
13.00
transmission???
will my stock 98 gt Transmission work with a cobra motor
i just got a 98 cobra motor cheap and im thinking about putin it in my gt my questions are will it bolt up or do i have to do some mods will my gt Transmission work is there anything else i need other then the computer |
MM's Orangest
2004 Mach 1 Mustang
Both used the same tranny so it should be a direct swap. And like you said just mess around with the computer so it will recognize the new muscle.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
97TT Gobra
dyno queen
the trans will bolt right up.....the comp is good but you can get a flash tune cheaper with a dyno...and itll move out....did a 4v swap in mine awhile back...all stock motor...410 gears, headers and exhaust...went 12.89 108..i think it was...
97TT Gobra For Sale 697rwhp 662rwtq no one to play with but the dyno |
13.1@105
![]() ![]() iTrader: 7 reviews
would it be the same for 04s?
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees! |
Make sure to use your GT tranny mount and crossmember. Otherwise your looking at cobra midpipes
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
13.1@105
computer wise
Thanks Brees! |
I had a brainfart sorry, I meant to say that if you use the Cobra trans then the cross member will be moved back to the end of the tailshaft of the transmission. And DOC the midpipes are different. I put a cobra tranny in my 97 GT and I couldnt reuse my midpipe I had to order one for a cobra. The converter was hitting the crossmember
N/A 4v Guru
2003 Mach 1
I have put a tru x from a gt on a termi with no problems. Most of them should be the same. The only time I have seen seperate ones are for the 3" termi mid pipes.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
My old car must be retarted the, Im talking stock exhaust-wise though
Threads Similar to: transmission???
| 99 gt transmission | ArmyChargedGT | 99-04 | 14 | March 14th, 2008 06:10 PM |
| transmission | mustangjl | 99-04 | 2 | January 31st, 2008 09:17 PM |
| Transmission | slowmustanggt | 5.0 Mustangs | 3 | January 7th, 2008 01:17 AM |
| Transmission Help!!! | Mstngdtb | 5.0 Mustangs | 9 | September 7th, 2007 05:19 PM |
| 01 3.8 Transmission | JBake | V6 Mustangs | 6 | November 2nd, 2006 08:45 PM |
