injector cleaner?
LinkBack (1) Thread Tools
Old June 13th, 2008, 09:01 PM   1 links from elsewhere to this Post. Click to view. #1
2003 Mach 1 Mustang
kevin86freeman is on a distinguished road
injector cleaner?
What is the best in tank injector cleaner?
And plz stay on subject
M.M. MACH1 CREW
Member 7
Old June 13th, 2008, 09:23 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Seafoam or Valvoline Full fuel system cleaner.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old June 13th, 2008, 09:38 PM   #3
Honeybadger is Crazy
futureMACH1racer's Avatar
2008 F-250 Super Duty
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Seafoam FTW!!!
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old June 13th, 2008, 10:03 PM   #4
2003 Mach 1 Mustang
i dont really know how to use it
M.M. MACH1 CREW
Member 7
Old June 13th, 2008, 10:40 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
half a thing of seafoam in about a half a tank of gas. Run the piss out of it till you are thru that half tank.
Military Crew
U.S. Army Aviation
Old June 14th, 2008, 12:21 AM   #6
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
Seafoam is supposedly the best and it's what I use most often. Other than that I usually use whichever brand goes on sale for something crazy like a $1. This week was Gumout. I buy a new brand every so often, last time was Shell, before that, Exxon. I can't really tell a difference in any of them, I mean I don't think anyone could unless you baked your injectors full of junk on purpose or something and then cleaned the snot out of 'em.
Old June 14th, 2008, 05:24 PM   #7
2003 Mach 1 Mustang
I heard you can put seaform in ur oil? how does that work?
M.M. MACH1 CREW
Member 7
Old June 14th, 2008, 06:06 PM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Cleans out the crank case and all the oil passages. You can only run it for a few minutes then you need to drain it all and change the oil. Its a pertroleum based product so it will start breaking down everything in the oil and you don't wanna have it in there very long. I don't think you need to do this. I would run it like I said up there, then maybe suck some into the manifold thru the pcv hose. That will help clean out the manifold and heads.
Military Crew
U.S. Army Aviation
Old June 14th, 2008, 07:16 PM   #9
2003 Mach 1 Mustang
ok well i ran the crap out of it yesterday
the reason i ask is because the mach is almost at 80,000 and i dont know if the past owner did anything to keep the motor at peak performance.
Anything else i should do?
M.M. MACH1 CREW
Member 7
Old June 14th, 2008, 07:41 PM   #10
When is the last time that you changed the fuel filter, flushed the coolant, dropped the tranny fluid, etc...
Old June 14th, 2008, 07:42 PM   #11
2003 Mach 1 Mustang
you know what i havent changed anything since i got it.
i should check into the...
just maybe
M.M. MACH1 CREW
Member 7
Old June 14th, 2008, 08:37 PM   #12
Do work son, Do work
Old June 14th, 2008, 09:12 PM   #13
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
like stated above flush the coolant, change the tranny fluid, spark plugs, ect.
seafoam is some good shit. i usually put about a third of a can into my intake and same thing in my crankcase, the rest in my gas. I run it for about 250 miles then i change the oil. Works wonders man.
Old June 15th, 2008, 12:39 AM   #14
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Replace all the fluids with royal purple, and do the fuel filter like FM1R said.
OOOO and don't forget to rotate the air in your tires.
LOL
Military Crew
U.S. Army Aviation
Old June 15th, 2008, 01:39 AM   #15
yes, Royal Purple FTW!!!
Old June 15th, 2008, 04:23 PM   #16
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
check or replace the spark plugs. Of course keep up to date on the oil changes and all of the above
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old June 15th, 2008, 04:27 PM   #17
You got it bro
Old June 16th, 2008, 04:12 PM   #18
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
Does royal purple really offer that much of an advantage over Mobil 1 with SuperSynt tech.?
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old June 16th, 2008, 05:00 PM   #19
I like it, I change my oil every 3000mi, and it's not even dirty. Great stuff IMHO!!!
Old June 16th, 2008, 05:18 PM   #20
1996 Ford SVT Cobra
13.36@102
I ran Seafoam in my crankcase for quite a while over the 250 suggested miles on accident more or less. I think I hit 500. My car lived through it fine.
For some reason Seafoam through my intake didn't give me the spectacular smoke show I was hoping for. I wanted my car to be Cheech & Chong afterwards, but all I had was a sputter at 55,000 miles and it's a 1996.
Tomorrow I'm going to pull the intake apart - again and clean out my IMRC to make sure I'm getting the most out of my high RPMs. If you have a car equipped with IMRC (96-98 Cobra mainly), the best way to clean your engine out is still tearing the intakes apart. Get all that oil out of there and really give those butterflies a nice blasting of carb cleaner, brake cleaner, whatever else you want to give it. Obviously this won't do anything in the cylinders or to the fuel injectors (must run something through the tank or manually clean the injectors) but there is no liquid solution to cleaning the motor out like there is good ol' arm power.
I read I need to remove my coolant crossover tube, pretty sure that seems excessive to get to the butterflies.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/75731-injector-cleaner.html
injector cleaner? This thread Refback June 14th, 2008 05:39 PM
Threads Similar to: injector cleaner?
Lucas fuel injector cleaner and fuel filter Saleen0101 Modular Mustangs 0 September 25th, 2007 04:09 PM
real quick injector cleaner question usmcsawgunner 5.0 Mustangs 10 June 17th, 2007 05:52 PM
fuel injector cleaner WilltheThrill Modular Mustangs 4 March 28th, 2007 10:28 PM
Fuel injector cleaner 1stimeford 99-04 1 March 20th, 2007 08:32 AM
Engine Cleaner MnrlGry01gt 99-04 11 August 13th, 2006 10:53 AM
