2003 Ford Mach
Traveling at the speed of a photon
Trans. Cooler
Are the Mushimoto trans. coolers more efficient in dissipating heat than our stock units? Since were on the subject, what benefit would i get from swapping out the radiator as well? Are the stock radiators just good enough?
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
2003 Ford Mach
My search for the results have been inconclusive.
N/A 4v Guru
2003 Mach 1
Tranny cooler is worth the swap, not sure about the Mushimoto but getting a better on is definatly worth it. The radiator does just fine. I haven't seen too many late model mustangs ever swap out the radiator unless they are track monsters.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#4 | |
2003 Ford Mach
Are you willing to send me a link for the trans cooler? I need to get one asap.
N/A 4v Guru
2003 Mach 1
yep here you go. Got a few choices depending on how much cooling you need
TCI - TRANSMISSION COOLING PRODUCTS: Coolers, Fans, Gauges, etc...
you can only cool an automotic tranny?
#7 | |
2003 Ford Mach
N/A 4v Guru
2003 Mach 1
Yea. the manuals don't build up heat like the auto's do. The manual is like you rear end, its gears and synchros, not much in the way of extreme heat. The auto has bands and clutchs and valves, and the fluid is under pressure, lot more friction in the auto and alot more potential for extreme heat.
#9 | |
Threads Similar to: Trans. Cooler
| Trans Kit and Cooler and Exhaust? | willsurforbeer9 | V6 Mustangs | 5 | December 23rd, 2007 08:17 PM |
| cooler | mpboy | 99-04 | 3 | October 15th, 2007 10:52 PM |
| cooler thermostat? | 94pacecarSVT | 94-95 | 4 | September 9th, 2007 01:49 PM |
| cooler plugs | cdunc24 | 5.0 Mustangs | 2 | January 21st, 2007 02:17 PM |
| C4 Cooler lines | New88MustangOwner | 5.0 Mustangs | 4 | December 6th, 2006 09:21 PM |
