Discussing 65mm in the 4V / SVT Forum. I have the Accufab, and I would've had the stocker P&P before ...
Old July 9th, 2008, 08:45 PM   #21
futureMACH1racer's Avatar
2004 Mach 1
Too Slow
I have the Accufab, and I would've had the stocker P&P before buying it, if I could do it over again.
MM MACH 1 CREW MEMBER #2
Old July 10th, 2008, 01:26 AM   #22
Doc8224's Avatar
2003 Mach 1
Originally Posted by ZOOTOXIN View Post
I guess so , I know the 1700cfm is right but couldnt tell you different about the 140mm+, but they describe and sell it as 65mm big oval and that is what I have.
AccuFab 65mm Billet Cobra Throttle Body(1696cfm) Single Blade "Big Oval" Throttle Body Kits
Polished Oval Throttle Body -CNC Machined Throttle Body
Adds up to 25+ RWHP
Part# ACC-CTB2003T* $ 379.95
I have 480 to the rear and 512 torque. I dyno'ed a little higher than most pulled cobras and I bet because a lot of people don't switch the TB.
Just do the math realy. An aftermarket twin 65mm=130mm total opening. The big mouth doesnt have a center section so its alot bigger than 65mm. Never heard of it called a 65mm big mouth.
Project N/A 4V Under Way
Old July 11th, 2008, 07:13 PM   #23
ZOOTOXIN's Avatar
its big oval not a big mouth- guess some one else called it that. But you are right that makes sense with that center missing.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Threads Similar to: 65mm
BBK Twin 65mm tb weems 4V / SVT 14 May 21st, 2008 12:52 AM
65mm outside "tube" size bigger than stock? will this cold air fit a 65mm? 91cobra5.0 5.0 Mustangs 0 February 7th, 2008 07:24 PM
65mm throttle body the biggest? obdnanr V6 Mustangs 23 February 6th, 2008 09:19 PM
65mm EGR wanted fogged306 Want to Buy 2 May 10th, 2007 02:02 PM
almost new EDLEBROCK 65mm T/B vfast For Sale 1 January 28th, 2007 08:33 PM
